    anyone know were i might download one of these.
    scm tech 95l User manual or parts lists
    am picking one up tomorrow.
    OR, if anyone has used one (scm tech 95l) am looking for the lifing footprint or advice on how to orientate the cantilever part so it does not move when lifted )
    any advice will do ??....;->
    Is this any good to you George?
Name:	Tech 95 L.pdf
    Si.
  3. The Following User Says Thank You to firetrappe For This Useful Post:
    hi firetrappe thanks for the parts list manual i wonder if you or george have got hold of a user manual i have a smc tech 95 its been in a corner in the work shop since i got it (n yes ebay ),now i need to get it going but am completely new to cnc would be grateful for any help
  5. #4
    yes i will dig it out for you mate, i saved all the manuals and parts lists that peope showed/supplied me.
    I searvices mine, so let me know if you get stuck. Its a big machine to start with but not to hard.
    Whats your intent for it.
  6. #5
    Quote Originally Posted by george uk View Post
    im based up north in manchester was hoping to do kitchen units and bedroom furniture but at the moment can not get away from shopfitting. i have found the parts manual but still could do with a user manual
    thanks for the reply
  7. #6
    will do, i might have to scann it ( its big ), so i will do it friday or saturday.
    Its ideal for kitchen and wardrobes. there are some special codes as part of the g-code, but nothing unusual. i think i have a copy of the setting disk and some other bits you will find usfull.
    Tips
    when servicing bearings and so, the parts manual does not always show you all clips and screws. I got stuck on the main X screw baring for a while. they are easy enough to service though
    2. Take time to make sure you set the feet properly, so the the weight is spread over the full lenght ( stop any slight twist on long jobs ) even if you have had it stood for a while, true up the shape by adjusting the feet
    final,,, saftey barriers and e-stops are a must on these type machines... they look fabulously dangerous whilst in operation. massive green iron comedy splatting type cnc machines
  8. The Following User Says Thank You to george uk For This Useful Post:
  9. #7
    Thanks, i have spent a few hours trying to track down these, best brush up on my italian, but the pictures do the trick perfetlcy anyway
    100% exactly what i needed. thanks
  10. #8
    No worries. The PDF is in about 4 languages, English is there if you look carefully.
    I found it on a US site if it helps in the future : https://www.partspronto.com/
    Good luck with the new toy :)
    Si.
  11. #9
    that was invaluable firetrappe thanks, These are one solid machine, and apparently am not he-man any more, or so every muscle in my body is screaming at me. Had to leave it outside the workshop till the morning. Start work on upgrading it tomorrow
  12. #10
    Hi, I bought an old (1999) SCM 120 cnc router, not working (ebay again). I decided not to try to upgrade the machine, but had the NUM controller updated from windows95 to XP. The main control cabinet looks fairly similar to yours. Perhaps the biggest disadvantage with not reconfiguring the machine is that the controller only recognises .XPI input. I have to save the nc file as .XPI in the post processor and then transfer that into the NUM controller. No problem at all, but it took a bit of getting used to. You are dead right, those old SCMs are very heavy and solid, well built machines. Placing the machine in position (pallet truck and machine skates) took some doing. My machine uses the spinning nut on the long axis and standard (all very heavy duty) turning ballscrew on the Y and Z. I suspect that your machine is very similar. These machines are real workhorses and I hope to hear that yours is once again earning its keep. Good luck. Geoff.
  1. Replies: 5
    Last Post: 26-01-2024, 10:18 AM
  2. Replies: 50
    Last Post: 01-07-2022, 04:11 PM
  3. FOR SALE: Boxford Vertical Machining Centre 190VMC Excellent Condition
    Last Post: 12-11-2014, 09:54 AM
  4. Replies: 1
    Last Post: 01-07-2014, 07:41 PM
  5. Dust and Chip extraction for large matrix table machining centre.
    By gavztheouch in forum Dust Extraction & Collection
    Last Post: 29-05-2013, 10:03 PM
