    Hi people,
    I'm about to upgrade my kress spindle to a 2kw or over spindle. I need a 1/2 inch collet so I'm guessing that would be an ER20 ?
    ebay as you know has loads of Chinese spindles but is there anything I should be looking for when choosing?
    Also any advice on water or air cooled would be great. The least noise the better !
    Finally, is there anyway I can control spindle speed from mach 3 ?
    Currently switched by the breakout board relay but I wondered if there was a vfd and a control board that talks to each other to make this happen ?
    Many thanks
    M Pecker
    Quote Originally Posted by Metal pecker View Post
    I use these and find they work well however as people have pointed out before there are probably better alternatives.
    SYSTEM1
    System45 (spindle boards are at the bottom of the page)
    I'm using Mach3, ABB vfd, 2.2kW spindle. The spindle board plugs into the breakout board socket so no extra wiring and it supplies 0-10v dc to the vfd for speed control.
    In Mach3 I have the motor tuning/spindle set so that the reported speed is the same as the actual speed and I use the relay on the spindle board to send a 'RUN' signal to the vfd.
    So when running G-code the speed is determined by the S instruction, e.g. S20000, in my case the spindle would run at 20000 rpm, M5 switches the relay, I always have it set to run forward (you don't want reverse direction). I also have set in Mach3 a delay of 10 seconds (5 secs would be okay in reality) to allow the spindle to reach full speed before the G-code starts the first instruction.
    The standard Chinese supplied vfd's would work just as well with this sytem.
  3. What are you milling mostly? If milling metal alot you might want to look at the 3kw spindle even though it does not give you a bigger ER collet (cheap buggers a ER25 would be so much more useful) it does give you a rather good increase in torque at the lower end of things and certain metals prefer things a bit slower to get nice good chips to be produced. Just a suggestion. -Michael
    CAD software Shark Pro v10, Also Aspire v9.0
    CAM Software Aspire v9.0, CamBam v1 beta12
    CNC Machine: http://www.mycncuk.com/threads/3661-...Second-machine
    3D printers: 2 x Prusa MK2S soon to be 2.5's and 1 x mini Delta (180 x 180)
    Work with Solid Surfaces, Acrylics, Woods, Foamboard, PLA, ASA, PMMA
    Work Computer: Lenovo D20, K4000, Tesla C2070, 64GB RAM
    www.marino-customs.com
  4. The Following User Says Thank You to m.marino For This Useful Post:
  5. #4
    Thanks Eddy,
    Sorry, I haven't been on here for ages.
    thanks for your reply. I think I need to pretty much strip all the electrcs out and start again with my machine now.
    I now keep having problems with my twin ballscrew steppers losing steps sending the gantry out of alignment.
    The physical wiring connections are ok, Velocity and acceleration on the motor tuning have been reduced.
    I mostly use the machine for drilling shelf peg holes for kitchen cabinets, each panel has 20 holes approx, it usually gets through 4 or 5 panels but then drops steps !
    Any clues ?
    Because it is used for work, I could justify up to about 2000 budget on upgrading it particularly as I want closed loop steppers and a decent breakout board with a spindle speed control.
    Many thanks
  6. #5
    Hi Michael, I mostly use the machine for drilling holes and cutting 18mm melamine faced chipboard for kitchen cupboard construction but I would like it to be able to cut 40mm oak worktops and belfast sink cut-outs etc
    Many thanks
  1. Improve Kress TIR or get an upgrade?
    By Hauk in forum Kress Milling Motors
    Last Post: 23-02-2014, 05:18 PM
  2. eBay: Kress 1050 FME-1 Spindle
    By viz in forum Items On eBay UK
    Last Post: 21-08-2013, 03:04 PM
  3. Secondary Kress spindle mount.. Does it exist?
    By fasteddy in forum Kress Milling Motors
    Last Post: 18-08-2010, 04:25 PM
  4. Aluminium Kress Spindle Holder
    By Lee Roberts in forum Metalwork Project Showcase
    Last Post: 15-07-2009, 11:00 PM
  5. Kress Spindle Holder
    By GTJim in forum Kress Milling Motors
    Last Post: 25-05-2009, 06:02 PM
