Thread: need help
22-01-2011 #1
Hi every oone just wondering if any of you can help i have morbidelli 504 and ive just set it up but the electro spindles are going in the wrong direction. any one ever have the same prob or how will i fix this thanks.
22-01-2011 #2
Just done a quick google, and see that's quite a 'substantial' machine!
I'm guessing the spindles will be powered by 3 phase, so it sounds like you just need to swap two of the 3 phase wires around, which will change the direction of all the 3 phase motors.
23-01-2011 #3
hi thanks ive thought of that but because its a electro spindle changing the wires wont make any differance as far as i know i think its got to do with the signal the machine is sending to the motor im not sure if there is just a setting on the set up that you can change when loading the program.
23-01-2011 #4
How are you starting the spindle
G code, MDI, hardware panel button ?
Phil
Sent from my HTC Desire using Tapatalk
23-01-2011 #5
I would of thought the spindle on that size of machine would be some form of 3 phase motor, either powered directly or via a VFD.
Swapping the wires to the machine would only take a couple minutes, and rule out it being something that obvious...
Is it possible to control the spindle speed?
23-01-2011 #6
hi phil startin it with g code runnin a program
23-01-2011 #7
hi swapped the supply today made no change to the direction. would have been i nice fix if it worked
23-01-2011 #8
24-01-2011 #9
ok cool ill give that a go and ill see what happins
thanks phil
30-05-2014 #10
Did you get any manuals with your 504 ? I have the full parts manual for it 729 pages - 5 languages ... but after an operators manual or something useful ... !
And what have you made on your 504 ?
g
