29-04-2014 #31
I'm sure that you will not get the machine to run on single phase as it is at present. It would mean sacrificing some some elements (reduced spindle power, smaller or no vac pump etc.), but I suspect that the cost and other problems of installing 3phase or using a large generator is likely to rule out keeping the machine as 3phase. I am fairly sure that from what has been said a small unit with 3ph already installed will also be a non-starter, and anyway I know that you , your friends and neighbours will not relish the idea of moving that beast again. These machines are likely to have have a power requirement of at 10-12KVA and I think you will find that is "pushing" your luck if you try to run it on single phase in its current configuration. G.
Advice needed on Amadeal
By croy in forum General DiscussionReplies: 13Last Post: 21-08-2015, 01:28 PM -
bit of advice needed for first mill
By jmac80 in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 06-04-2014, 10:59 PM -
Quick Advice Needed - F&S
By Tenson in forum Tool & Tooling TechnologyReplies: 1Last Post: 01-01-2013, 06:38 PM -
First steps, advice needed
By Wobblycogs in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 02-11-2012, 02:30 PM -
Advice needed for Z Design
By Hobgoblin in forum Linear & Rotary MotionReplies: 8Last Post: 10-09-2012, 09:18 PM
