    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 22 Hours Ago Has been a member for 6-7 years. Has a total post count of 251. Received thanks 1 times, giving thanks to others 11 times.
    This might be a daft question, but I'll fire away anyway. I'm using a 1:1 ratio on a motor (with a gearbox) to shaft transmission, using HTD5 15mm wide belt / pulleys. Does it matter how big the pulleys are, or can I go with whatever size I want? I know that with 1:1 ratio torque / speed transfers over to the driven end, but maybe there's a reason to use smaller pulleys rather than big ones? only thing I can think of is inertia and how fast the pulley can move / stop.
    Regards,
    T.
  2. Inertia is one key parameter. Another is how many teeth are engaged v the torque you want to transmit. Also consider belt radius and therefore flex which translates to belt life.
    dsc's Avatar
    Thanks irving, didn't think about teeth engagement vs. torque. I'll be using a 400W servo (1.27Nm, peak torque of 3.82Nm) with a planetary gearbox, 12:1 ratio, this will then be coupled to a shaft via pulleys and 1:1 ratio. I doubt I will ever exceed 20Nm on the drive side, but I'd rather be sure the pulley arrangement can take the maximum 45Nm just in case. Ramp up / down speeds aren't a big issue here, so bigger pulleys should be fine, I just need to google for some teeth / torque calcs.
    Regards,
    T.
    Don't forget Jonathan's spreadsheet too.
    http://www.mycncuk.com/forums/machin...t-lengths.html
  1. WANTED: TG 100 Collets in various sizes
    By gavztheouch in forum Items Wanted
    Last Post: 28-10-2016, 01:51 PM
  2. AC Motor upgrade - pulley sizes
    By birchy in forum Linear & Rotary Motion
    Last Post: 21-06-2013, 09:49 PM
  3. pulley ratios on 3 pulley axis
    By Swarfing in forum Belt Drive, Pulleys & Timing
    Last Post: 20-07-2011, 11:43 PM
  4. Belt drive and pulley sizes
    By j2sip in forum Belt Drive, Pulleys & Timing
    Last Post: 20-06-2010, 09:44 AM
