Page 3 of 3 FirstFirst 123
  1. #21
    Quote Originally Posted by rwb97 View Post
    I had to leave the XP machine as it just couldn't cope, even with the kernels set at 25Khz, but I'll install it on my main PC tonight and look forward to trying your suggestions! Thanks very much.
    Don't set the Kernal speed higher than 25Khz if it does everything you want which it will with just 24V. The Kernal speed isn't directly related to how fast your PC is but more how good your parallel port is. I've seen some high spec PC's that just can't touch some much lower spec PC's because they have fast clean pulses coming from the Parallel port.
    The further away from 25Khz you set the Kernal the more chance you will have for trouble.!
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  3. #22
    Ahhh that's interesting, thanks for clearing that up!
  4. #23
    If you want to test how good your parallel port is then run the Driver test in Mach3 folder.! . . . Look for file called Driver test.!! . . . This will show better if your PP is up to speed.?
  6. #24
    Just another thought about pins :- the enable pins for the axes might be better set high, even though the TB6560 has internal pull-up resistors, a floating pin could cause problems. X=4, Y-17 and Z = 5.
  7. The Following User Says Thank You to cropwell For This Useful Post:
  8. #25
    Yeah, found the driver test when I was trying to get it to work when I was trying on windows 8, Will try it on 7 when I get home, thanks for your suggestion! I will also try those enable pin settings.
  1. Stepper motor tunning wiring
    By handyoodman03 in forum Stepper & Servo Motors
    Last Post: 11-01-2013, 04:49 PM
  2. Stepper Motor Wire Colour Codes
    By c cunningham in forum Stepper & Servo Motors
    Last Post: 26-01-2011, 01:13 PM
  3. CY or SY cable for stepper motor wiring?
    By Jonathan in forum General Electronics
    Last Post: 26-09-2010, 05:25 PM
  4. Stepper motor wiring
    By Buba b in forum Stepper & Servo Motors
    Last Post: 28-03-2010, 05:16 PM
  5. Stepper Motor Wiring (Screened?)
    By pequod in forum Stepper & Servo Motors
    Last Post: 03-08-2009, 09:15 AM
