  1. #31
    Hello Suesi34e, Paul_m and JAZZCNC
    I am new onto here.. I have been reading through this thread as I recently purchased a Denford Microrouter V5 PRO NS for a price I couldn't resist... I've was looking at building something like and oozenest system but now this has come along id like to stick with and upgrade it to mach 3 thus removing the need to use the Denford software and the RS232 connection... By the looks of it you have completed a similar upgrade and they're running reliably :-) could you please let me know what you used for the conversion and how you did it? Any information would be greatly appreciated :-)
    thank you for all you help!!
    Ian
  2. Quote Originally Posted by ihulston79 View Post
    Ian
    Hi Ian,
    the big questions will be, how much are you willing to spend, what performance are you looking for, and how good are you with electrics/electronics?
    The conversion can vary from a minimum budget cheap BOB and some wiring/possible soldering using the original stepper motor drives, through to a complete new motion controller, stepper drives, and stepper motors.
    Off course, you can change things gradually, as the cheapest option may work perfectly well for you, and then upgrade later if you feel you need some extra performance.
  3. #33
    Thank you for the reply
    I would like to have a good robust system, simple to use that I can do anything from detailed carving to cutting aluminium with. basically I bought my Microrouter direct from a school, it had just had a new Porter Cable fitted and I could have it for £200, so theres definitely room in the pot to upgrade, and anything I do add will hopefully add value to it.
    I've been intouch with Denford and by the time I've brought a licence for their operating system etc i'm already £700 in so don't want to be limited to that option plus it will have its current performance still...
    I'm not the best with electronics, I have dabbled in the past.. I can do basics, soldering etc etc... I need directing in the best direction, what to buy etc...
    Thank you for your help
  4. Quote Originally Posted by ihulston79 View Post
    Ian, probably best to start your own thread, and if you could post up some photos of the control cabinet internals, that would help us provided some suggestions.
  5. #35
  1. FOR SALE: Marchant dice cnc router mill compatiable with mach 3
    Last Post: 23-03-2021, 12:59 PM
  2. Denford digiplan 300 drivers, i cant get them to run on mach 3
    By scnc in forum Motor Drivers & Controllers
    Last Post: 30-04-2014, 09:56 PM
  3. Emco Compact 5 Conversion
    By Pete92 in forum Emco Lathes
    Last Post: 01-10-2013, 11:31 PM
  4. convert traditional machine or build router?
    By Henrik in forum Gantry/Router Machines & Building
    Last Post: 22-03-2013, 08:49 AM
  5. mach 3/ router help wanted: ayrshire
    By advertisigndirect in forum Artsoft Mach (3 & 4)
    Last Post: 05-02-2010, 11:56 PM
