Thread: First CNC
    Hi from London. I am in the process of building my first cnc wish me luck..
    Good luck with the new machine.
    At what stage are you at? Rough idea with some sketches but no bits, or putting it all together. If you want any advice or suggestions just say so. You'll get better replies if you mention things such as cutting area, materials to be cut (wood, plastic, aluminium etc.) and any other requirements.
    And do start a build log - always good to see other projects.
    EDIT: Doh! You've started a build log (Extrusion CNC build) so ignore all the above except for the good luck bit.
