Page 2 of 2 FirstFirst 12
    Thanks guys, I have tried various things and have now got it to zero return. I have had to change the following, X to 13 Y to 10 and Z to 12 and active low ticked on all of them. As I said, home ref works to switches and the only problem now is the jog wheel in X operates in the wrong direction, this because I needed to change motor output Dir low active on the X axis to a tick in order for it to ref home in the right direction.
    Quote Originally Posted by Sparky View Post
    Ok well easy sorted.!!
    Goto Config/ System hotkeys then on left side where it says "Jog Hotkeys" Click scan code for the Axis direction you want and then press the key direction you want.
    Hi Jazz
    Thank you for that, but unfortunately that did not work.
    Hi Jazz
    Think you best explain again the problem because changing the keys would change the direction unless you didn't apply the changes by clicking ok.?
    The other thing to try and really what you should have done instead of changing the X motor active state is to use the Reversed option in the Homing/limits. So set the X motor state back to previous state and try this and between this and changing the keys you'll get moving in the right directions.
  5. #15
    Hey Jazz, all sorted now, many many thanks for your help. Its been a good learning curb for me and helped me to understand the configuration of the machine.
    Regards
    Sparky
  6. #16
    Regards
    Sparky
    Hi Sparky,
    I think I've got the same controller as you (labelled CNC SuperBox on the front).
    I've struggled to find any documentation for it online and can't work out the pinout for Mach3 to control it.
    Have you a manual you can send or a list of your pin mapping?
    Many thanks,
    Sam
  7. #17
  8. #18
    Hi EddyCurrent, yes!
    Thank you, it's listed as an SBOX which is why I think Google was struggling to bring up many results when I've been looking for Super Box (as per the front panel).
    I'll have a read through that and should be able to figure it out now, thanks for your help.
  1. Huanyang VFD control plugin for Mach3, USB RS-485
    By JayPunchbuggy in forum Spindles & Drive Motors
    Last Post: 15-05-2013, 07:00 PM
  2. 2 motors on X how do I setup Mach3
    By phill05 in forum Artsoft Mach
    Last Post: 04-02-2013, 08:33 PM
  3. Mach3 / Offsets / Tool setup etc
    By dudz in forum Artsoft Mach
    Last Post: 20-11-2012, 02:51 PM
  4. New CNC Router Setup Tool For Use With Mach3
    By CambiumMachines in forum Manufacturer News
    Last Post: 08-06-2012, 03:14 AM
  5. HID interface for remote control of Mach3
    By Smiler in forum Electronic Project Building
    Last Post: 10-05-2009, 11:59 AM
