    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 31-03-2024 Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Hello all,
    I'm currently building a small parts tumbler in which I intend to tumble aluminium parts amongst 3mm porcelain beads.
    Some pics below:
ID:	12364 Click image for larger version.
ID:	12363 Click image for larger version.
ID:	12362 Click image for larger version.
    Although the 12v 350mA 20RPM motor spins the tub reasonably well (provided that the static friction remains low) I'm thinking of adding an identical motor below it and connecting it via a nitrile o-ring belt so that it's 'helping out' the motor that's directly driving the tub, like so:
    Now, let's say that an O-ring with an inside diameter of 100mm fits perfectly (un-stretched) around the two couplers:
    I'm guessing that this wouldn't be ideal as there'd be very little traction or transfer of torque - so my question is: how much stretch percentage should I introduce to the o-ring for it to do its job as a conduit between the two motors? 10%? 20%?
    Cheers!
    Wal.
  1. idea for linear belt drive
    By dickieto in forum Rails, Guideways & Bearings
    Last Post: 28-02-2021, 05:33 PM
  2. Belt drive on a router
    By John S in forum Rails, Guideways & Bearings
    Last Post: 10-09-2012, 09:39 PM
  3. WANTED: wanted drive belt and pulleys
    By oadamo in forum Items Wanted
    Last Post: 13-05-2011, 09:00 PM
  4. any one know where to get a belt drive convertion for x2
    By Scott in forum Sieg Milling Machines
    Last Post: 27-09-2010, 08:44 PM
  5. Re: Standard Drive Belt Size ?
    By HS93 in forum Belt Drive, Pulleys & Timing
    Last Post: 18-05-2009, 03:30 PM
