11-05-2014 #1
H-Bot 3D Printer HB1 dry test No.22 - YouTube
anyone done that yet?
with the torch height from a cable
yes, with dual shaft motors, with twin belts top and bottom or single?
twin bar y axis with turn-buckles each end between them for tensioning.
does anyone make a idler pulley mount that slots into 45mm t-slot ends
would you use a single 25mm belt 2525mm long closed loop and get a table about 400mm square
2525mm divided by 6 -= 420mm square so 600 by 220 or 500 by 320mm
or would you d twin 15mm pulleys top and bottomso as to not stress the motor shafts so much
COULD you in fact run 4 motors one in each cornerLast edited by nobby; 11-05-2014 at 04:17 PM.
10' x 5' Plasma table design
By Kerryfisher in forum Plasma Table MachinesReplies: 4Last Post: 20-02-2013, 09:28 AM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
RFQ: RFQ: Plasma Table
By D-man in forum Projects, Jobs & RequestsReplies: 3Last Post: 04-07-2010, 11:08 PM -
3M x 2M Plasma table build
By MonoNeuron in forum DIY Plasma Build LogsReplies: 14Last Post: 01-09-2009, 11:11 AM -
Plasma table 2m x 1m
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 9Last Post: 19-05-2009, 12:48 PM
