    Job is now closed
    I would like a quote for the attached part (3D pdf, hope it is accessible...)
    Batch of 40 pcs.
    Overall dimensions: 110x60x8mm
    Material: AL6063 (could provide stock)
    Finish: satin, 'soft' anodized black (turn-key preferred, but not required)
    Tolerancing: to DIN/ISO2768-MK or equivalent
    Min. radius: 0.5mm (3-axis cnc)
    The part requires external threading M2.5 x 0.45 (the four pillars). This can be left out, done manually, or circlip grooves can be cut instead - I am flexible.
    Priority over low price vs turnaround time.
    Many thanks,
    Alex
    Attached Thumbnails Attached Thumbnails base metal top viewport.PDF
  1. Milling Sheet Aluminium
    By p1lts in forum Metalwork Discussion
    Last Post: 07-03-2014, 11:23 PM
  2. 6082 aluminium milling directions
    By dudz in forum Metal Finishing Techniques
    Last Post: 16-02-2014, 09:42 AM
  3. RFQ: Looking for Aluminium CNC Milling Service + Lathe Work (2 Separate Jobs)
    By biketrialsdave in forum Projects, Jobs & Requests
    Last Post: 19-02-2013, 03:06 PM
  4. Home Anodising Aluminium and the elusive Sulphuric acid
    By GeorgeD in forum Metalwork Discussion
    Last Post: 01-02-2013, 02:07 PM
  5. RFQ: 20mm Aluminium Plate Milling Request
    By Tenson in forum Projects, Jobs & Requests
    Last Post: 01-06-2012, 10:56 AM
