16-05-2014 #21
Isaac
Can I ask where you got your tube and power supply from ?
18-05-2014 #22
I got the supply from aliexpress and the tube from cncoletech on ebay :)
I use the big laser for sign/shape cutting and the small one for engraving mainly. Whats the plan for yours?Last edited by Isaac; 18-05-2014 at 05:36 PM.
18-05-2014 #23
ah .. I've seen coletech .. and wondered if they were to speck !? I was thinking of buying a higher power tube and power supply and upgrading my cutter. Keeping this one for backup.
Are you happy with the tube / process of shipping etc ?
18-05-2014 #24
Yeah, first one arrived broken, I sent a couple of pics and within a couple of days he had another sent out to me :)
18-05-2014 #25
was it signed for, then you found it broken ?
Or did you check before you signed for it ?
As I've seen that in the terms and conditions ?
18-05-2014 #26
I signed then opened and found it broken. If you refuse delivery I believe you can drive to the parcelforce mail center and open it on their premises to check it.
The coletech guy was fine, within 10 mins of me sending the pics he told me another was being sent :)
I bitched about it on twitter to parcelforce.
18-05-2014 #27
ok .. the deal breaker ! ... would you buy from them again ?
My parcelforce is 5 mins away, but no guarantee that is who it will arrive by !
I'm really impressed with the capabilities of the software and controller etc. .. you can set laser power as a percentage of speed, so it doesn't burn in the corners etc .. Lot's to learn .. but I'm very glad I didn't go with the cheaper option :) It does path optimisation, recover from failed run/power fault .. loads of advanced features !
I can see me ordering another when I get it up and in production :)
.. and then another ....
18-05-2014 #28
The Following User Says Thank You to Isaac For This Useful Post:
18-05-2014 #29
Thanks .. usefull info :)
another question missed .. what do you cut with yours ?
MDF ? Plastic ? Engraving ?? etc ..
18-05-2014 #30
All of the above :) Plywood too.
Laser Machine Grounding/Earthing
By Want2build1 in forum Laser Machines & BuildingReplies: 31Last Post: 09-02-2015, 10:18 PM -
Laser Machine Eye protection
By Want2build1 in forum Laser Machines & BuildingReplies: 11Last Post: 19-05-2014, 01:46 PM -
How to save laser machine cost
By Zoe Zhang in forum Manufacturer NewsReplies: 0Last Post: 06-09-2012, 03:41 AM -
Chinese CNC machine modifications - Discussion
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 14-05-2012, 06:51 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM
