    hi all looking at a conversion to a sieg x2plus and its looking like 12mm ball screws. my concern is that a usual drive spigot for this is 6mm and I was wondering to its strength, any imput? thanks in advance
    What size motors are you proposing to use ? these ones have a 6.35mm shaft for example,Nema23 Stepper Motor 2.2Nm
    This might be useful reading, http://www.ausrocketry.com/forum/vie...hp?f=32&t=4002
    Many thanks,eddy,probably the ones you have put,will read up tonite at home,head is filling up with data sheet info,I even think some of it is making sense aswell,ball nut support blocks to draw up next. All good fun. Cheers...
  1. dc motor - spindle / shaft drive
    By dsc in forum Spindles & Drive Motors
    Last Post: 01-06-2013, 09:42 AM
  2. I need advise again
    By habibuzziwa in forum General Discussion
    Last Post: 08-10-2012, 09:08 AM
  3. I need advise
    Last Post: 03-10-2012, 09:50 AM
  4. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 12:52 AM
  5. Ho do you measure end mill diameters?
    Last Post: 20-11-2011, 11:04 PM
