  1. #31
    Quote Originally Posted by SWMS View Post
    If you bought the machine from China I would earth it using the spike. It could be that parts of the machine are electrically isolated from each other. In which case, knowing how they connect the laser tubes, I wouldn't fancy 25 volts bouncing around the frame. :) Basically as he above said. :)
    25V won't hurt anyone but 25Kv will. It is true that it seems in these lasers the current meter is connected to the ground side of the 25KV and if one side of the meter becomes disconnected it could be a bit hairy ..Clive
  2. #32
    you have to consider it in more detail than that !
    It depends on your current earth setup.
    If my earth is from the elec provider .. and I install a spike .. there could be considerable difference in potential from one earth to the other .. this would cause a large current to flow in the earth wiring.
    If I was to add a spike in the workshop, it would be best to use that earth for the whole workshop, and "lift" the incoming earth from the supply
  1. Earthing?
    Last Post: 29-03-2018, 10:56 PM
  2. Laser Machine Eye protection
    By Want2build1 in forum Laser Machines & Building
    Last Post: 19-05-2014, 12:46 PM
  3. Laser diode module machine addon
    By luke11cnc in forum Laser Machines & Building
    Last Post: 06-01-2014, 10:24 PM
  4. How to save laser machine cost
    By Zoe Zhang in forum Manufacturer News
    Last Post: 06-09-2012, 02:41 AM
  5. WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
    By Brownhills school in forum Items Wanted
    Last Post: 10-05-2012, 03:30 PM
