    Found this on Indestructables.
    Looks like quite a nice build.
    Any comments on the design?
    Building your own CNC router/milling machine
    A respectable starter / mid performance machine, and fine for wood plastics etc.
    He mentioned machining aluminium - ok for engraving but it would not be suitable for accurate machining:
    Single ballscrew on X (racking)
    Limited bed support causing workpiece deflections (due to single ballscrew design)
    Very high gantry sides (tool deflection/vibration)
    Gantry cross member on the small side (tool deflection/vibration)
    Kress spindle (run out?, plus noisy)
    Z axis plate too thin (10mm?)
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 1 Week Ago Has been a member for 6-7 years. Has a total post count of 376. Received thanks 41 times, giving thanks to others 15 times.
    It does look like a very tidy build and yes, well documented.
    Results look pretty good - the Aston badge has come out well. You'd have to say that it's perfectly capable working at the lighter end of fabrication. Almost definitely will struggle to hold accuracy with thicker cuts, but crikey - ain't that every DIYer's story..?
    I did find myself vigorously itching my chin reading this bit, though:
    "To get all guiderails perpendicular and parallel to each other they were all aligned with a dial indicator (with a maximum difference of 0,001 mm)."
    Really? On that frame?
    Interesting that he hasn't fitted limit/home switches. Otherwise a pretty and a decent build. Good on him.
    Wal.
    Very neat design for what it is and he/she done well on such a low budget.I echo a lot of routercnc improvements I also think single block bearings may not resist the leverage that the tall gantry is going to apply to them but hey the sample pieces look great and this diy machine is a lot better than the offering from some pretty big companies and kickstarter ventures.
    ADD ME ON FACEBOOKS
    Last Post: 08-02-2017, 07:03 PM
  2. FOR SALE: Nice aluminium rack mounted enclosure, possible casing for cnc electronics
    By drumsticksplinter in forum Items For Sale
    Last Post: 23-08-2013, 11:48 PM
  3. eBay: Nice CNC USB Pendant with Touch Screen 2.8 for Mach3
    By Ricardoco in forum Items On eBay UK
    Last Post: 26-03-2013, 11:16 AM
  4. Nice one Roy at DIYCNC
    By routercnc in forum Motor Drivers & Controllers
    Last Post: 26-10-2010, 01:31 PM
  5. OT Not cnc'ed but a very nice mechanism
    By BillTodd in forum General Discussion
    Last Post: 01-06-2009, 06:08 PM
