Page 1 of 14 12311 ... LastLast
    Hello, My name is Mike and im 20 years old. I have been using Solidworks for a few years and have become quite fluent with the software. I am keen to turn some of the parts I design(mainly Rc related) into life by the use of a CNC. I understand the concept and have sent Dxf and Stl files to companies to have parts cut and printed for me but would like my own CNC.
    Could any of you folk out there point me in the right direction for a CNC.
    Basic requirements
    1) Be able to cut woods,plastic,carbon& glass fibers, Aluminium
    2) be easy to assemble if required,easy to setup
    3) cost less than £1200 for machine including electronics. ( CAM and Mach3 already acquired)
    it would be a rel help :)
    Hi Mike
    Welcome to the forum.
    If you let us know the size of components you intend to produce, our more knowledgeable members will point you in the right direction, a lot tend to build there own as you can end up with a good machine for a lot less cash than some of the commercial stuff that's available.
    Regards
    Mike
    dazza's Avatar
    Lives in leicester, United Kingdom. Last Activity: 3 Weeks Ago Has been a member for 9-10 years. Has a total post count of 363.
    hello mike
    there is nothing off the shelf that I know of within 1200 quid range other than these Chinese 6040 machines that are all over ebay
    im thinking something along the lines of 600x600x100mm working area... Could you guys fill me in on what you reckon is best of these which I have found so far.
    CNC1 - I have seen videos of this machine with good results gutting aluminium
    CNC2 - I like the look of this machine but there is not much about it online...looks good but i hear allot of chattering while cutting aluminium
    CNC3 - I like this one because of its low cost but am feeling quite skeptical of its linear movement mecanism, looks like it could be sloppy after allot of use
    Thanks guys, so far this is what i have managed to find with my limited knowledge on these machines.
    Hello FlyHighRC,
    What sort of tolerances are you looking to achieve with the aluminium?
    What thickness of alu are you wishing to cut?
    Is cutting time a factor?
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
    dazza's Avatar
    you be pissed off in no time shelling out for them then cutting aluminium
    these are the 6040,s I mentioned 3-axis CNC 6040Z-S65J Router Engraver Milling Drilling Cutting Machine CNC 6040 | eBay
    at least some of them come with a water cooled spindle but I still wouldn't buy that,with aluminium in mind ,although some get by with em and they have a following,with a 1400 quid budget consider making one
    Hi
    i dont think i would bother with any of those, like the others sya, you could build your own for that, a little more money, you could build one 10* better. There are already some good designs on here and some already done in sketchup for the size your looking for. I will try find the ones i was looking at in sketchup, they was compleate, I would imagine all them have rigidity and accuracy problems.... You may get away with cutting a wing profile in foam with them, but i think, ( am also into RC ), you might struggle with smaller componants on them. especialy hard small parts ( alu car frame, helli bits, cam holders ). Do You FPV ?
    Quote Originally Posted by george uk View Post
    Hi
    Well CNC 1 has been on youtube and seems to go through aluminium fairly easily..6mm 6061 alloy and seems to do it in very little passes. If i wanted to build my own are there any build videos of a known machine where the parts are easy to findbuy and assemble? Id imagine getting the thing tuned would be a bi*ch.
    Yeah I am into FPV. I Design Quadcopters mostly. I do love flying FPV and also do allot of survey work
    I live on the coast, and its so relaxing FPVing the coast, and buzzing boats in the humber. I prefer planes, but love team blacksheep vids with quadcopters... I doubt they get permission.
    The more rigid the frame, the easier to get repeatable accuracy, your best bet i think would be read through some of the build logs, you will see what problems people overcome, and will see why them three that you pointed at are a basic,
    So what would I need? I wouldnt mind designing my own design and sticking up some renders on here for you guys to approve..If I build it I could then upload the files for anyone else to have a crack if the design works :) I suppose if its a homebuild then I could Increase its work area right?
    The things I know Ill need
    1)Steppers motors
    2)Stepper wire
    3)Link stuff
    4)Controller
    5)Stepper Drivers(Any all in one driver boards?)
    6)Linear mechanisms? Any recommendations for for round bar or square rails?
    7)Some sort of router..again any suggestions?
    8)sacrifical bed, i see this this is most often MDF
    Have I missed anything?
    Where can I buy extrusion? And any dimensions online? Would really help with putting this all into Solidworks :)
    Thanks again guys
  1. Need advice for a new machine?
    By az786again in forum General Discussion
    Last Post: 05-03-2014, 02:04 PM
  2. NEW MEMBER: Designer with a plan looking for advice
    By bigstu67 in forum New Member Introductions
    Last Post: 10-10-2012, 06:04 PM
  3. Advice about a sentence concerning CNC Machine!!!
    By hoezap in forum General Discussion
    Last Post: 09-11-2011, 02:25 AM
  4. cnc machine buyers advice
    By wyndham in forum Marketplace Discussion
    Last Post: 29-06-2011, 06:52 PM
  5. Machine Buying advice
    By jrob3rts in forum Marketplace Discussion
    Last Post: 17-09-2010, 04:59 PM
