Thread: NEMA23 mount for BK12
24-04-2017 #1
I was wondering what people have been using as a NEMA23 mount to use with the BK12/BF12 bearing blocks.
One option is the ready made MBA12-C that accepts an FK12 for the fixed side.
Has anyone come up with an alternative of their own? The NEMA23 centerline is at 28.2mm, the BK12/BF12 axis is at 25mm. Therefore all that is needed is a way for the motor to sit 3.2mm below the plane on which the BK12/BF12 are fixed.Last edited by auhopu; 24-04-2017 at 11:06 AM.
24-04-2017 #2
Just to be clear, this mostly applies to a custom Z axis.
X & Y will usually have their own end plates in place where a motor can be mounted appropriately.Last edited by auhopu; 24-04-2017 at 11:31 AM.
When my ballscrews come I'll tell you lol ;)
I bought these
http://www.ebay.co.uk/itm/2624523999...%3AMEBIDX%3AIT
and need to mount it to this style mounting bracket
http://www.ebay.co.uk/itm/2525494066...%3AMEBIDX%3AIT
according to the drawings there is a 14mm difference between the centre of my nema 23 mount and the centre of the BK12/BF12 bearing blocks.
Luckily I found a piece of scrap tool aluminium that's been milled flat to 14mm from a commercial printer so I intend to cut it down to make "spacers" for the bearing blocks from solid tool aluminium which should align perfectly.
I might have enough spare pieces to make a few spacers if you're stuck send us a PM.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
10mm belt nema23
By kev20009 in forum Belt Drive, Pulleys & TimingReplies: 29Last Post: 31-01-2017, 05:19 AM -
RFQ: RFQ Nema23 stepper mount
By r0bsk1 in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-02-2014, 02:16 PM -
BK12 end float?
By birchy in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 20-07-2013, 02:28 AM -
BK12 & BF12 bearings
By mlmSolutions in forum Lead Screws, Nuts & SupportsReplies: 0Last Post: 04-01-2011, 11:16 AM -
DIY Nema23 Motor Mounts
By Lee Roberts in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 23-08-2009, 06:08 PM
