Thread: New machine Z axis
07-06-2014 #1
So I am doing the design for my new machine and am currently looking at the Z axis.
I had intended to make both the fixed plate and the moving plate both from 30mm thick ali but I dont have enough so it looks like a small design mod is on the cards.
I have enough 30mm thick for one plate and enough 20mm thick for the other one or both.
So going by using the 30mm thick and the 20mm thick whats the opinions on whether the back or front plate, fixed or moving plate, should be the 30mm one? I thought that I would make the moving plate or front one from the 20mm plate seeing as it will have the linear rails fitted to it to improve stability and make the fixed or rear plate from the 30mm thick stuff.
Any ideas either way?
07-06-2014 #2
Someone will correct me if I am wrong, but I would say 20mm is enough, so any combination you choose will do.
Personally, I would go with 30mm front plate.Last edited by ivars211; 07-06-2014 at 08:14 PM.
07-06-2014 #3
Yea 20 minimum, any lower and your going towards sheet.
.MeLee
07-06-2014 #4
Definately 30mm on Front plate, you'll never bend 20mm on rear but you will bend 30mm plus rails on front if you twat it hard enough.!! I've seen my 20mm plate with rails on bow like banana when shit's hit fan.!!
09-06-2014 #5
Thanks guys. Looks like 30mm on the front then.
Syil x4 or x5 as CAD/CAM training 4 axis CNC machine ???
By towdi.arek in forum Marketplace DiscussionReplies: 3Last Post: 20-07-2013, 07:26 AM -
Millford ..LOW COST CNC 3-AXIS DRILLING MACHINE (£240) New UK
By Fivetide in forum Marketplace DiscussionReplies: 1Last Post: 09-05-2013, 10:36 PM -
thinking about this Syil X5plus CNC Milling Machine with 4th Axis
By Dellboy in forum Marketplace DiscussionReplies: 8Last Post: 22-04-2012, 05:52 PM -
4th Axis running as CNC lathe using milling machine
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 21-08-2011, 10:34 AM -
BUILD LOG: Belt driven 3 axis machine
By Swarfing in forum DIY Router Build LogsReplies: 14Last Post: 21-02-2010, 10:46 PM
