    Quote Originally Posted by deisel View Post
    im looking forward to seeing how this performs,thanks for posting ;)
    You're not the only one!
    I finished rewinding the motor the day before yesterday, so here it is ready to varnish:
    Checked the back-emf constant was correct by spinning it in the lathe and measuring the peak voltage with oscilloscope. Then powered a small light bulb with it for general amusement...
ID:	12699Click image for larger version.
    I tested the motor with my driver last night, just open loop control - will post a video if anyone's interested.
    I started a job at university yesterday, so progress will be slower for now. I'll instead concentrate on finishing off the motor driver design and making them.
    loved the bolt spacing theory so thanks for sharing that, cant wait to see the rest, keep up the good work !
    Since you seem to like bolts, here's my justification for putting four setscrews in the motor pulley...
    A setscrew works by applying a force which results in a contact force between the opposite side of the shaft and bore. Based on the tightening torque of the setscrew, we can calculate this force and if the co-efficient of friction between the shaft and bore is known, the holding torque can be determined - approximately of course.
    For one screw it's very simple - the axial force on the screw is equal to the contact force (C) between the shaft and bore, so:
    The motor shaft diameter is 12mm, we can fit M5 grubscrews, they're black and according to this list the tightening torque is about 4.7Nm, so substitute that lot in:
    With multiple screws, we have to resolve the forces to find the effective contact force. Define the angle as the angle between the two screws, then resolve the force on one screw in the radial direction and double it to get the radial force for both screws:
    I put the screws spaced at 90° because it makes milling the flats on the shaft easier, but this formula shows that the smaller the angle between the screws, the greater the holding torque, so 60° would have been better. For 90° that reduces to ., so now we have .. That torque is a little greater than the motor rating, but shock loads could impose much higher torques so I added another two screws further along the shaft to double the load capacity.
    Some pictures I forgot to post of testing the motor:
Name:	DSC05502 (Large).JPG
ID:	12780Click image for larger version.
Name:	DSC05500 (Large).JPG
ID:	12781Click image for larger version.
Name:	DSC05498 (Large).JPG
    A week ago I made some progress with the power drawbar in preparation for the ATC system, here's a quick video to demonstrate:
    More to follow in a couple of weeks, other projects getting in the way...
  4. The Following User Says Thank You to Jonathan For This Useful Post:
  5. #14
    I got the ATC working this weekend - at least in principle:
    I've made quite a few parts for the carousel etc, but they're all quite simple so it didn't take long. There's a few issues I've mentioned in the video - the main things are to add sensors, change the coupling between the carousel and gearbox for something stiffer and check the clamping torque upon the toolholder. It's currently just controlled using a few lines of gcode - the air solenoids are currently controlled from LinuxCNC via relays just using the M64/M65 commands and delays. When I've got time I'll do it properly, so sensors are checked at each stage (using M66) to avoid mishaps.
ID:	13399   Click image for larger version.
  6. The Following User Says Thank You to Jonathan For This Useful Post:
  7. #15
    Looking good, it will be interesting to see it working under real load conditions but it looks like a first on this forum.
    Well done. ..Clive
  8. #16
    dazza's Avatar
    Lives in leicester, United Kingdom. Last Activity: 5 Hours Ago Has been a member for 9-10 years. Has a total post count of 363.
    Now that's porn,16 tools..it looks smart..i vaguely remember you mentioning mesa/pico hardware for this mill,did you bother.
    will the turret be bidirectional and take the shortest route to the next tool or..not that it matters it seems quick enough.
    nice work.
  9. #17
    I almost forgot - I did try cutting with the DC motor and it seemed fine, but that's not a good comparison considering how much higher the torque rating of the new motor is.
    Quote Originally Posted by diesel
    For now I've decided it's too expensive for what it gains - more and faster I/O. If I need more inputs/outputs I can add a 2nd parallel port and until I use servo motors the frequency limit of the parallel port is adequate. One temptation for using a motion controller is it could fit in the back of the column, so I'd be able to get all the electronics inside the column.
    Yes - that shouldn't be a problem. I've currently tuned the carousel motor to run with quite low top speed and very low acceleration as the low stiffness of the coupling means it oscillates too much if I run it faster, so it will certainly be quick enough when that's fixed.
  10. #18
    Believe it or not, I found some time to work on this project again!
    Decided I should do some sort of drawings for the X & Y axes, so here's the rough idea. I say rough as most of these parts are just blocks to show the general arrangement of things - I've not added detail:
Name:	Screenshot 2016-01-01 14.34.15.png
ID:	17006Click image for larger version.
Name:	Screenshot 2016-01-01 14.33.43.png
    The X axis uses a bed from a different machine. I'm adding HSR35-1100mm rails to this and SHS25 rails to Y. These rails sizes are based on what I've got good deals on. For the ballscrews I'll be buying TBI DFU ballscrews, similar to Z, sized to get a reasonable stiffness for each axis.
    As a 'first pass' look at it, I've tabulated the stiffnesses of each component, then combined these (as springs in series) to get a value for the stiffness of each axis:
    This implies that the stiffness is dominated by that of the ballscrews, as these are by far the smallest numbers in the table, so it is worthwhile to invest more in 'large' ballscrews as improving these should have the biggest effect on the overall stiffness of the axis. For the table above I've calculated the stiffness's based on DFU2005 on X and Y, with angular contact bearings on both ends of the X-ballscrew, to compensate for the lower stiffness of such a long ballscrew.
    This analysis is still too basic though, as it assumes the forces are all applied at the respective axis center of stiffness, since moments aren't considered, so I need to re-calculate including the 'pitch' and 'roll' stiffness of each axis. If this shows that the ballscrew stiffness is still significantly lower than the linear bearing stiffness, then I'll consider using even bigger ballscrews.
    So far I've started machining the bed and steel spacer strips to mount the rails, that's about it...
  11. #19
    So today, I got from this:
Name:	DSC00140 (Medium).JPG
    Via lots of this:
Name:	DSC00143 (Medium).JPG
    To this (cute little HGH15 bearing is for scale):
Name:	DSC00150 (Medium).JPG
    Next job is to drill and tap more holes than I care to count in the bed, which I can barely lift as it weighs more than me, so that's going to be fun... then I'll make the aluminium plates which fix on the steel strips that poke out of either end. Finally, I plan to get both sides of the bed surface ground so that the rails have a nice accurate surface to mount upon.
    I also started drawing how I plan to mount the X-axis ballscrew drive end:
Name:	Screenshot 2016-01-02 02.29.27.png
ID:	17037   Click image for larger version.
Name:	Screenshot 2016-01-02 02.29.56.png
  12. #20
    Fantastic build Johnathan, thanks for posting, always get very envious looking @ your projects.
    Regards
    Mike
  1. Warco WM16 Mill - Conversion to AC motor with VFD
    Last Post: 10-02-2022, 07:41 PM
  2. X2 Mill motor Problem
    By A11an in forum Milling Machines, Builds & Conversions
    Last Post: 20-01-2022, 12:26 PM
  3. Replies: 2
  4. Help and Advice sought about new motor for my mill
    By alanb in forum Milling Machines, Builds & Conversions
    Last Post: 26-01-2012, 08:04 PM
  5. FOR SALE: Mini Mill spindle motor + controller etc
    By pjm in forum Items For Sale
    Last Post: 22-06-2010, 07:34 AM
