Page 6 of 15 FirstFirst ... 45678 ... LastLast
  1. #51
    Thanks,
    Lee, its copper grease just running out a bit, didnt want any of the coolant corroding the bottom of the rail and causing the table to lift, although minimal i may aswell do it while i can.
    Yes the dowels are there to push the rails towards the machined datum edge. Both edges 'should' be parrallel with one another.
  2. #52
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Has been a member for 9-10 years. Has a total post count of 2,558. Received thanks 171 times, giving thanks to others 659 times. Made a monetary donation to the upkeep of the community. Referred 10 members to the community.
    Ah right both cool ideas I haven't seen before so thanks!
    Have you dialed them in with an indicator as well?
    .Me
    .Me
  3. #53
    I will run a dti over them when i put the blocks on, but should be parrallel as the steps were machined in one setup. Touch wood!
    So more progress!
    Added the holes to fix a plate onto the back of the main pillar
    Mocking up the plate ready to drill and tap 20 holes with a hand drill :(
    Y axis plate all mounted with rails too, time to start adding the rest! Will be starting to get heavy!
  4. #54
    Heavy z pillar going on now. Weathers starting to get cold now so i need to start priming some of the metalwork to stop it from rusting.
  5. #55
    Looking very nice!
    .Me
  6. #56
    Very nice build, I especially like the T-slotted x-axis bed.
    Dave
  7. #57
    It is I'm very envious and can wait to see her cutting...
    .Me
    .Me
  8. #58
    Thanks both of you, been really slow progress the past couple months had a member of family in hospital about a 100miles drive away in plymouth. And my daughter is due very soon so is going to be slow from now, but hopefully will get some time in the garage, :/
  9. #59
    Looks like proper quality, spot on.
  10. #60
    Started off looking awesome - now its getting better!!! G.
  1. WANTED: cnc milling machine
    By bigred5765 in forum Items Wanted
    Last Post: 25-04-2014, 11:08 PM
  2. WANTED: X3 CNC milling machine
    By Nemo1966 in forum Items Wanted
    Last Post: 09-11-2013, 10:42 PM
  3. WANTED: Milling machine head
    By Ainis in forum Items Wanted
    Last Post: 23-07-2013, 09:30 PM
  4. New CNC Controller for Milling Machine
    By antsals in forum Electronic Project Building
    Last Post: 08-04-2012, 06:09 PM
  5. First CNC milling machine help
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 05-09-2011, 10:06 PM
