    Hi all
    I am trying to implement EddyCurrent's flasher circuit but am having issues with it. He uses a System1 V2 BOB and I am using a PMDX 126. In a PM EC explained he used the BD679 as follows:
    Pin14 from the BOB connects to the base of the BD679 via a 2.2k ohm resistor. The emitter is connected to 24v negative and the collector is connected to one side of a "lamp". The other side of the lamp is connected to 24v positive. The flashing is controlled by a brain supplied by EC.
    Now, I built this little circuit using a 24v LED as the lamp and it just glows in a low light and does not flash at all. I have PM'd EC asking what his "lamp" was but at this point he has not replied. I am now suspecting the "lamp" may be just that, a light bulb and not an LED. My LED is a true 24v LED in a pushbutton size package.
    Can anyone see what I might need to use the 24V LED in a circuit such as this AND have it flash as required from the brain?
    Any help would be appreciated.
    Bruce
    Sounds like it should work provided the base of the transistor is being driven high by the BOB (break out board ? Sorry, I'm new to this site having just purchased a mill to convert). The BD679 is a darlington device so won't need much base current to switch it on.
    It sounds like the transistor is missing its base drive - perhaps you need to configure something in your CNC software to make Pin 14 a suitable output ?
    HTH
    Robin
    Thanks Robin
    The problem is it *is* working in as much as the led is on all the time instead of off until flashed. I checked Mach and the output flashes in the diagnostics screen. I'll reconfigure the circuit again (have tried 4 transistors so far) with one of the last 10 transistors I have. I'll also get a 24v lamp to test it if I can find one today.
    Bruce
    Well it is definitely something I am doing, EC just replied to my PM and he is using the same style LED lamp as I am. I'll check I have everything the right way round and report back.
    If you're sure that you pave the pins connected correctly (see attached) then the next suggestion, assuming you have a multimeter, is to measure the voltage between the base and emitter of the BD679 to check what the BOB is sending. Name:  BD679_Pinout.gif
    Robin
    Hi Robin
    Just ducked down and checked the pinout and all as per required. Measured the voltage as suggested and got 0.04v yet the LED is glowing and not flashing. Just for kicks I measured between the base and the collector and got 12.67v. The brain was active and "flashing" yet it made no difference to the LED. If I disconnect the parallel cable the LED goes out even with power still applied to the BOB. I have tested this with 2 different BOB's, a PMDX 122 and an MB06-v2 from homann designs in Aus, both show the same behaviour. The LED stays lit even when pin 14 (assigned to OUTPUT1) is disabled. Got me stumped at this point.
  1. AM882 Alarm Circuit
    By Wobblycogs in forum General Electronics
    Last Post: 28-03-2014, 06:06 PM
  2. -10V to 10v circuit
    By vre in forum General Electronics
    Last Post: 15-01-2014, 12:15 AM
  3. E-STOP Circuit - will this cause any problems?
    By birchy in forum General Electronics
    Last Post: 18-12-2012, 04:35 AM
  4. DC motor drive circuit?
    By Tenson in forum General Electronics
    Last Post: 02-02-2012, 10:32 PM
  5. Milling Printed Circuit Boards - How To
    By Lee Roberts in forum Electronic Project Building
    Last Post: 28-08-2008, 11:25 PM
