Thread: My Build
Page 1 of 5 123 ... LastLast
    Well itís been nearly four years since I started to look at building my own machine, my interest started because I was looking for an alternative to using chemicals for making printed circuit boards, after finding a home built CNC controlled PCB engraver on Ebay I started searching and soon found CNC building forums like this one.
    After reading a lot of the threads I started to design my own machine using Autocad, because my initial interest was PCBís I was only looking to build a small machine , I started to acquire various bits, the first being three Gecko 210 stepper drivers and three Nema 34 stepper motors.
    Fortunately for me (or unfortunately depending which way you look at it) I work in a factory which uses quite a bit of automation and over a period of time I have acquired a lot of very lightly used ball screw assemblies, linear rail and carriages and aluminium extrusion which has dictated the final size of my machine and already with bigger sections becoming available as I write this I am redesigning it already.
    I built all the electrical/electronics first. My power supply is home built giving me around 50 volts dc to power my steppers and capable of delivering around 16 amps. Although I have had my machine running it is still very much work in progress, I have purchased a MPG, a small PLC with MODBUS capability to give me more I/O and also I have just received a three phase water cooled spindle and VFD all of which require fitting and setting up . Anyway thatís enough of me babbling on, as they say a picture paints a thousand words here are a few photoís, I have also taken some video of it cutting some MDF nothing exciting so once I figure out how to upload it I will do so.
    Specs at the moment:-
    X Axis 650mm
    Y Axis 650mm
    Z Axis 200mm
    5mm Pitch Ball Screws On All Axis
    Hiwin 25mm Rails And Carriages on X and Z Axis
    Hiwin 30mm Rails And Carriages on The Y Axis
    Gecko 210 Stepper Drivers
    3Nm Stepper Motors On All Axis
    CNC4PC 11T BOB And the C10
    Mach 3
    Regards
    Andy
    Im not sure how the photo's will upload so here goes
    Well not very well, Lee if you are out there this is the message I received
    "Your submission could not be processed because a security token was missing.
    If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error."
    The action I performed was to try and upload some photo's from my pc
    I will try again later
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Has been a member for 9-10 years. Has a total post count of 2,551. Received thanks 166 times, giving thanks to others 654 times. Made a monetary donation to the upkeep of the community. Referred 10 members to the community.
    I'm looking into it as we speak andy !
    .Me
    Well I will try again with the photo's I will just try one to start, if it is successful it shoul be some of my parts after machining ready for assembly
    Quote Originally Posted by audioandy View Post
    Drool.....
    All that lovely precision guided railery, you lucky man!
    Looking forward to seeing this machine come together Andy and really looking forward to anything you might have to say on your MODIO stuff too
    Jeff.
  6. Looks like he means business :)
    I like the hand scraped and levelled trusses ;)
    Ok that seems to have worked.
    So
    The next photos show my machine through various stages of my build.
    The first is a side view of my built up Z axis,the next is my X axis and Z parts built. The next part I built up was the table that it all was going to sit on.
    After mounting to the table I started to wire in my limits and homing switches these all terminated into a junction box on the rear of my gantry I used shielded cable where possible then used a multicore shielded cable to connect them to my main control box.
    The main control box was fastened to the side of the table then the Y axis was built up and assembled.
Name:	Built Z axis.jpg
ID:	410   Click image for larger version.
Name:	x and z together.jpg
ID:	411   Click image for larger version.
ID:	412   Click image for larger version.
Name:	Axis mounted to table.jpg
ID:	413   Click image for larger version.
Name:	Rear junction box.jpg
ID:	414   Click image for larger version.
Name:	Rear Junction Box connected.jpg
ID:	415   Click image for larger version.
Name:	Y axis table parts.jpg
ID:	416   Click image for larger version.
Name:	y axis built up.jpg
ID:	417   Click image for larger version.
Name:	Y axis side view.jpg
    Wow replies already thanks guys.
    Yes Bill those trusses are older than me! They have started to rot but I dont want to throw them away as they were built by my grandad when he was an apprentice wheel wright.
    Ok so here are some photos of the electronics side of things
Name:	control cabinet.jpg
ID:	419   Click image for larger version.
Name:	Powered Up Controller.jpg
ID:	420   Click image for larger version.
    And here is the future "to do" list, first photo shows the 2.2Kw spindle and VFD, I have had this powered up and ran it up to 24,000 RPM it is so smooth and quiet carn't wait to get onto the machine and try it.
    The next is the MPG this was purchased from Gary at Zapp,after talking to Jeff to find out how he had connected his I realised I was fast going to run out of I/O so I purchased the CUBLOC plc which has modbus connectivity. I have had this connected to my control PC and managed to fire outputs : ).
    As I progress through the above "to do" list I will keep you posted with my progress (or not)
    Well thats about it for now.
    Andy
Name:	VFD and Spindle.jpg
ID:	422   Click image for larger version.
ID:	423   Click image for larger version.
    Last Post: 08-02-2017, 07:03 PM
