23-07-2014 #1
Ok. I can mill 2D objects no probs.
I wanted to mill a simple semi circle slot along the horizontal plain of the material. The circular slot is to be 120mm long / 11.113mm deep
This picture is just an example I made so you can see what I am trying to do. I have milled the object all apart from the slot on the left.
What is the simplest way to do this ?. I have today tried to create a 3D version in FreeCAD software, but when imported to Cambam, I have no Idea what to do with it. Especialy as I only want the slot. Maybe there is a way in Cambam, that lets me do this without getting into 3D ?Last edited by dudz; 23-07-2014 at 03:31 PM.
23-07-2014 #2
whats the radius of the slot? or is it a true semicircle so diameter = 22.226mm (spurious level of accuracy aside), or 7/8". Maybe you can find a 7/8" ball nose cutter.
The Following User Says Thank You to irving2008 For This Useful Post:
23-07-2014 #3
23-07-2014 #4
23-07-2014 #5
Hhhmm chinese spindle. I dont know if the speed will cope too low with such a large endmill . If Cambam wont do it, what software will ?
Or maybe something inside Mach3 ??Last edited by dudz; 23-07-2014 at 03:56 PM.
23-07-2014 #6
But you aren't trying to cut a semi-circular slot, you are trying to cut a semi-circular slot with something at the ends so the software knows what to do when it gets there. The tool needs to know where it can overhang.
Given half a chance any self respecting software will not view this as a pocket sinking exercise. That way it can cut the outline when it reaches the end. Simples.
The easiest way is to write a quick program that spits out a G code, that way you can be sure you get a finishing cut that increments to the face rather than the depth.
The Following User Says Thank You to Robin Hewitt For This Useful Post:
23-07-2014 #7
OK thx.
I just tryed the trial version of Meshcam. It was simple to do (on the pc)
Pitty I cant get Cambam to do it though.3 axis CNC/router / Alu profile frame....25mm Alu Cutting bed X=500mm Y=300mm Z=110mm.....Supported 25mm X rails ....Supported 20mm Y rails....Supported 20mm Z rails.....2.2kw Chinese WC spindle..... CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller....M542 Drivers..SY60STH86-3008BF Motors...running....Mach3 / Cambam / Emachineshop.
23-07-2014 #8
24-07-2014 #9
I would draw the slot as a line longer than you need draw a semi-circle to the size you want and extrude the semi C along the line, create your tool path using a bull-nosed cutter, using center line of where you want to put slot across the part, use this as XYZ = 0 set your cutter & g-code to run from there, it should cut a semi-circle across the part.
Phill
24-07-2014 #103 axis CNC/router / Alu profile frame....25mm Alu Cutting bed X=500mm Y=300mm Z=110mm.....Supported 25mm X rails ....Supported 20mm Y rails....Supported 20mm Z rails.....2.2kw Chinese WC spindle..... CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller....M542 Drivers..SY60STH86-3008BF Motors...running....Mach3 / Cambam / Emachineshop.
Setting rapids in CamBam
By swisscheese in forum CAD & CAM SoftwareReplies: 4Last Post: 04-04-2014, 02:30 PM -
Mach3 / cambam
By dudz in forum Artsoft Mach (3 & 4)Replies: 5Last Post: 01-04-2013, 06:02 PM -
Cambam / milling Alu
By dudz in forum CAD & CAM SoftwareReplies: 5Last Post: 23-12-2012, 05:22 PM -
Drilling Acrylic with CamBam
By m.marino in forum Machine DiscussionReplies: 2Last Post: 06-06-2012, 04:45 PM -
How do i make this in cambam?
By motoxy in forum CAD & CAM SoftwareReplies: 4Last Post: 09-02-2012, 06:01 PM
