Page 2 of 2 FirstFirst 12
  1. Possibly, but by time you've bought the LDO reg and other things and assembled it its not worth the hassle and the extra 12v output from these supplies is a bonus.
    A couple of months ago I bought a new BoB to replace the fried one originally from MD. The original has been discontinued, so I can't get a plug-in replacement. This is the one I bought http://www.ebay.co.uk/itm/Cnc-Router.../261633467531?
    The doubt that I have is that I intend to connect it to the drivers in common anode mode, but the 5v for this is derived directly from the USB connection (from my computer). I would have expected this 5v to be solely to drive the opto isolators on the PC side. The stepper drivers being given 5v derived from the 12-24v input to the board.
    I am a bit wary of putting 5v directly from the computer to the drivers (Tonman PD2064M).
    I would welcome advice on this as my confidence has been lowered when I found the direct connection.
    My machine has been out of action now for months and, due to illness, I haven't had the mental energy to put it back together.
    Cheers Mates,
    Rob
  3. Two options:
    A) use a separate 5v usb 'charger' (wall wart)
    B) my preference - use a 24v to 5v buck converter, e.g. eBay item 221546337415 - there are lots like this with either USB or screw terminal outputs.
  4. The Following User Says Thank You to irving2008 For This Useful Post:
  5. #14
    I have one of these boards but I use it for extra inputs only. I only have it connected to a 24V supply and I can confirm there is no 5v output, so it looks like you have to use the USB as well to get the 5v.
  6. #15
    Yes Eddy,
    I very much thought so me sen. I only bought it for the spindle 0-10v output, as I have got a couple of these boards http://www.embeddedtronics.com/image/opto/opto_new.jpg. I shall be using one to click relays and sense some inputs. I made 'em up myself so I have spare optos and I have the Eagle files, so I know the circuit.
    I just wish I had a circuit diagram for the cheap chinese board - Ah well !
    Cheers,
    Rob
    Now back to the Jim Beam therapy for this persistent cold I have had on and off (mainly on) for the last three months :)
  7. #16
    Rob
    I have a 24V power supply and rather than regulate down for some pcb's I am considering running a 5v from my PC power supply. Not being to electrical I can't see any reason not to.
  8. #17
    The purpose of the opto isolator is to prevent any damaging voltage getting to the I/O pins of the LPT port. You could connect directly from the port to the driver, but it is risky. If you get computers cheaper than decent BoBs then it might make sense to wire directly to the driver. 5v from the computer usb port should only provide power to operate the output pins from the computer. Take no notice of the Line designations, that is only relevant for printers, but the output pins(->) should be isolated with 5v power taken from the computer. The input pins (<-) should be isolated with their 5v supply taken from an external supply.
    In the end most things will work, but the risk factors are different.
    Cheers,
    Rob
    And Seasons Greetings to all who sail in her.
  9. #18
  1. How to change breakout board
    By GeoDurie in forum General Electronics
    Last Post: 23-07-2014, 06:44 AM
  2. Breakout Board
    By Tomnewry in forum General Electronics
    Last Post: 12-12-2013, 06:24 PM
  3. breakout board usb or parallel
    By crossleymarko in forum Motor Drivers & Controllers
    Last Post: 30-07-2013, 11:44 AM
  4. Breakout Board
    By croy in forum Electronic Project Building
    Last Post: 18-08-2011, 06:50 AM
  5. eBay: CNC Breakout board cheap - that will do me !
    By Lee Roberts in forum Items On eBay UK
    Last Post: 14-08-2009, 04:52 PM
