Guy I know had a machine converted to run on mach3, when I say had a machine converted what I mean is that someone ripped his old machine to bits, connected some of the new bits together & then disappeared leaving Wullie with a non working machine. I have tried to help out but not 100% sure what I am doing.
The PC running mach3 works fine & I have also tested it on my cnc to make sure it runs, the serial cable has also been tested, the motors are wired up round the right way & when the system is started you can hear/feel them lock. If you plug the pendant control into the BOB the motors all move the right direction as they should.
Now when you try to move any axis under mach3 control the axis light on the BOB lights the DRO on the screen moves but the motors don't any help would be really appreciated
