    Hi all im trying to set up my 60-40 cnc . now i have set it up as they say in the instructions on mach3 . i have just run some code and the part came out bigger that the drawing by 15.6mm . Im i rite in thinking this is something to do with the steps per --- ? the instructions say it needed to be 400 . any help would be great
    mick
    Yes it is, read this
    http://www.mycncuk.com/threads/7733-...0877#post60877
    Also this, they are using a different screen but the idea is the same.
    https://www.youtube.com/watch?v=EVrqObwaAF4
    thanks for that. i had am idea that the instruction was incorrect
    i love the internet that took me about 5 mins to change them . Now its perfect .
    Thanks again
    dont know if any one will pick this up . but i need recommendations for 4 core shielded cable. im gonna replace mine
    thanks mick. uk btw
    Quote Originally Posted by amxen View Post
    thanks mick. uk btw
    This is one place http://quickbit.co.uk/Cable/CY-Cable...-0-75mm-4-core but if you do a search on here you will find a better place (cable) or here; http://www.electrical-trader.co.uk/c...-cy-cable.html ..Clive
    Said it before but I'll repeat it because those 2 places are the same.? (Same number). . . . I don't like Quickbit cable as it's brittle and actually think it's the same stuff they use on these chinese machines, it's certainly feels like it.
    I use CSE cables. Never had any trouble with it and used 100's of meters. http://www.csecables.com/acatalog/CY-Cable.html
    thanks again all. is 1.5mm upto the job ?
    More than enough 1mm will be enough.
    Yes your dead right that was the company I was looking for but my brain failed. ..Clive
  1. NEW MEMBER: Contemplating DIY build; quick hi and q's
    By brumster in forum New Member Introductions
    Last Post: 16-12-2013, 03:03 PM
  2. a 4th axis... and quick
    By kingcreaky in forum Marketplace Discussion
    Last Post: 29-10-2013, 10:34 AM
  3. Need a quick hand with some resitors please
    By Fivetide in forum General Electronics
    Last Post: 07-04-2013, 07:58 PM
  4. quick reply box
    By wilfy in forum General Discussion
    Last Post: 01-03-2013, 10:10 AM
  5. Quick question
    By m.marino in forum General Discussion
    Last Post: 18-02-2011, 03:30 PM
