    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Has been a member for 9-10 years. Has a total post count of 2,557. Received thanks 170 times, giving thanks to others 656 times. Made a monetary donation to the upkeep of the community. Referred 10 members to the community.
    Hi
    Is there a standard set of drive belt size’s we should really be designing to or ?
    .Me
    HS93's Avatar
    Location unknown. Last Activity: 19-09-2012 Has been a member for 7-8 years. Has a total post count of 26.
    Is it standard belts your after for drive pullys then look at this
    http://www.hpcgears.com/calc.htm
    just put in the gears you are using and the space between them and it gives you the belt req
    but you may be talking about something else.
    Peter
    I've been using aluminium Imperial XL pulleys from RS who are actually quite reasonable priced, kind of freaky for RS to be reasonably priced but there you go.
    Many years ago we were writing software for a LARGE Russian XY table, only a vague recollection, lots of water under the bridge since then etc., but the bit I do remember was that it positioned using spring steel bands around rollers. Seemed a lot more practical than toothed belt and stuck in my mind.
  1. idea for linear belt drive
    By dickieto in forum Rails, Guideways & Bearings
    Last Post: 10-09-2012, 09:49 PM
  2. Belt drive on a router
    By John S in forum Rails, Guideways & Bearings
    Last Post: 10-09-2012, 09:39 PM
  3. any one know where to get a belt drive convertion for x2
    By Scott in forum Sieg Milling Machines
    Last Post: 27-09-2010, 08:44 PM
  4. Toothed belt size selection help.
    By cweeks in forum Belt Drive, Pulleys & Timing
    Last Post: 20-09-2010, 11:53 PM
  5. Re: Standard Drive Belt Size ?
    By HS93 in forum Belt Drive, Pulleys & Timing
    Last Post: 18-05-2009, 03:30 PM
