    I am looking for someone who can build me a machine.
    The machine itself is for making peg board signs so it has to produce a finished board size of 1200mm x1200mm. its not really a cnc machine as all it needs to do is to push a strip of metal into a grove with enough force to secure the fabric.
    sounds easy right!
    well each grove is 1.2 mm set the full width and every 10mm across the board. the strip of metal has to be 0.8mmin width and press down equally across the board. there also has to be some method to keep the board dead square to the pressure strip as if it goes out of square the board will be scrap.
    I will put a couple of pictures on to give you the gist of what I am trying to achieve and the current machine we are using.
    Many Thanks
    Dan
    It is not letting me put the pictures on, if anyone is interested I can email them over to you.
    Quote Originally Posted by Dannovodesign View Post
    I think you need to wait about 36 hours before you can post pic etc. ..Clive
    Sounds more like a pick and place machine, same principle as cnc though x,y,z axis, maybe somebody fancies building a robot arm instead ?
  1. BUILD LOG: Definately a scrapyard challenge
    By motoxy in forum DIY Router Build Logs
    Last Post: 29-10-2012, 09:12 PM
  2. BUILD LOG: Scrap Heap Challenge
    By TrickyCNC in forum DIY Router Build Logs
    Last Post: 16-09-2012, 06:52 AM
  3. NEW MEMBER: Up for a challenge......
    By swatt in forum New Member Introductions
    Last Post: 03-10-2010, 09:57 PM
  4. Fancy a challenge?
    By cassius in forum Machine Discussion
    Last Post: 03-09-2010, 01:44 PM
