Page 2 of 7 FirstFirst 1234 ... LastLast
    Ok I'm lost now. Are you saying the board I'm using won't take 36v or the drivers that came with the kit won't take 36v
    Lives in Marple Stockport, United Kingdom. Last Activity: 38 Minutes Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by amxen View Post
    Ok for the sake of clarity I take it you have two setups one purchased with the cnc and the other which is a set of drives and motors and a power supply is this correct. .Clive
    Yes that's correct
    I was going to make my own so I got all the parts together to make one. Then I found I don't have the time to prototype parts. So I thought I would buy one. . The photos and video are of the one I got form eBay. The link to the aliexpress is a kit of electrical parts I have that for the one I was going to ( May still do) make. But I can use the parts on the other if I need to. Not sure about the sub Bob now thow as I have a dedicated pc with a PP. Hope that's abit more clear. Thanks mick
  5. #15
    Mick In the absence of the master's on here (I am sure they will be around in a bit) let's see if you can get your original kit working. Frist alter the vel in Mach to say 1500mm/min and try that. (you have it set for about 2000mm/min).
    The other kit you have bought is better but not good. You need motors with low inductance. The drives in that kit will accept up to about 48V which is better and you could use them with the power supply from the kit.
    Don't get despondent there are plenty of people on here to help. ..Clive
  6. #16
    Hi Clive. I know the kit I have is not amazing but it's all I could aford at this time. I'm not too worried about my set up as I have it running ok tbh, just not at the seeds they say it will run.
    At the moment I have it set like this 320 - 1000-100. And it runs ok just a bit slow. This is fine for now as I'm just learning. But if I try any higher like say 320-1200-150 then it starts to randomly jam. At 320-1500-200 or higher it will jam all the time. I'm guessing the recommend setting are a sales lie by the eBay seller and not what the electronics are up to.
    But I would like to track the fault down so I don't junk what I don't have to when I want it to run faster.
    I'M thankful for all and any help I get on here.
  7. #17
    Mike Are you saying that your running at 1000mm/min on one axis and slower on the others? ..Clive
  8. #18
    No. X nY at 320-1000-100 and Z at 320-700-100
  9. #19
    Mike Is that code for steps, vel,acel ? ..Clive
  10. #20
    yes Clive the manufacture instructions say to set it to
    steps = 320
    velocity = 2000
    acceleration 200
    but if i go anywhere near this it stalls
    i have to set it to
    steps =320
    velocity 1000
    acceleration 100
    and at this i still get a bit of grinding sound some time.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Chinese 6040 from uk eBay seller x axis problem
    By CommanderKenyon in forum Gantry/Router Machines & Building
    Last Post: 20-02-2015, 02:13 AM
  4. my 6040 experience (yeah, and problems) so far
    By jimbo_cnc in forum Machine Discussion
    Last Post: 07-10-2014, 11:26 AM
  5. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
