10-09-2014 #1
Hello im new here and just got my first cnc machine but i am having a problem with the z axis, when i power up the control and press the reset button the quill drive turns on and moves the quill down about 25-30mm and turns off the drives if i reset the drives again the same thing happens, but if i raise the quill until it touches the upper limit switch i can control both x and y axis manually and through a program without using the z axis. I have been told by a servo repair tech that it is probably got something to do with the scales or the wiring as i have also tried switching the drives with the same result. Any help would be appreciated.
Dave
FOR SALE: bridgeport interact 4
By cutter23 in forum Items For SaleReplies: 2Last Post: 01-07-2014, 12:47 PM -
servo control vs stepper control
By Peter. in forum Motor Drivers & ControllersReplies: 24Last Post: 17-09-2012, 08:36 AM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM -
FOR SALE: Bridgeport x and y traverse units
By Philmollatt in forum Items For SaleReplies: 2Last Post: 18-11-2009, 06:35 PM -
WANTED: Bridgeport x and y bearing brackets
By Philmollatt in forum Items WantedReplies: 0Last Post: 10-10-2009, 03:22 AM
