08-10-2014 #1
Hi Guys
What are your thoughts and experiences when it comes to joining profile rails? On both precision and fully supported rails.
Since I am in South Africa and shipping items larger than 1500mm is problematic. If they dont get bent, then they charge rediculous amounts to move them around.
I am considering joining rails in order to get the desired length.
Is this possible?
Ockert-- if you can't be good, at least be good at it --
08-10-2014 #2
Page 10 (13 of the pdf) shows how to do it, if that's the sort of rail you mean.
http://www.hiwin.com/pdf/lg/0809/Hiw...9TE13-0809.pdfSpelling mistakes are not intentional, I only seem to see them some time after I've posted
09-10-2014 #3
I used a Masterwood for years that had a 14' X axis made up of joined rails. The joint was so tight that you almost couldn't see it. These rails carries several thousand pounds.
You can do it, but the joint should be precision ground, very, very accurately.
Having said that, I've also seen MDF machines using used Ebay rails butted together, with good results.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
09-10-2014 #4
the hiwin rails i got didn't have machined ends for some reason however i was able to mill and grind them good enough to get them running smooth so shouldn't be to much of a problem although the less the better i would say.
09-10-2014 #5
Thanks guys. Great to hear it can be done.
I suppose accuracy is one thing, but in my case it is more important to not damage the blocks.-- if you can't be good, at least be good at it --
09-10-2014 #6
Where the rails join, I would attach to the side, a block with a ground flat face, this would allow you to keep the rails in line similar to a railway fishplate.
"Hacking" and "Modding"
By magicniner in forum General DiscussionReplies: 15Last Post: 07-01-2015, 08:59 PM -
T and L profile Joining plates
By dudz in forum Marketplace DiscussionReplies: 2Last Post: 02-01-2013, 08:58 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM -
NEW MEMBER: Hello Im interested in joining you all
By Guisborough in forum New Member IntroductionsReplies: 3Last Post: 18-08-2010, 11:01 PM -
NEW MEMBER: Joining the "ship"
By Ali Kat in forum New Member IntroductionsReplies: 2Last Post: 13-08-2007, 08:49 AM
