    I am about to configure a "System 45" 3 axis unit by DIYCNC in the UK , can some one please advice on what timing setting I should use when using the StepConf Wizard in LunuxCNC.
    Also the instructions for the System 45 give the following setting for the drivers that I don't understand?
    1/2 step type B (0-100%)
    1/2 step type A (0-71-100%)
    Which should I use?
    Steve
    Best bet is to email Roy, be patient for a reply though
    Have you tried the default values for timing ? also do you really want 1/2 stepping ? it obviously depends upon the application but most go with 1/8 , in which case you dont care what (1/2 step type B (0-100%)
    1/2 step type A (0-71-100%)) means.
    Thanks for that I will give that a try, at the moment I am trying to get the parallel port address sorted!!!!
    Steve
  1. "Hacking" and "Modding"
    By magicniner in forum General Discussion
    Last Post: 07-01-2015, 07:59 PM
  2. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 05:21 AM
  3. Replies: 4
    Last Post: 28-09-2012, 11:06 AM
  4. "Racks" VS "ball screw"
    Last Post: 17-04-2012, 10:53 PM
  5. Replies: 1
    Last Post: 25-12-2010, 05:05 PM
