    AndyGuid's Avatar
    Lives in Berwick, Melbourne, Australia. Last Activity: 54 Minutes Ago Has been a member for 5-6 years. Has a total post count of 121. Received thanks 18 times, giving thanks to others 174 times.
    I recently lucked this work bench for a few quid....... the top is a single piece of cast aluminium 1300 x 730 of minimum 12-13mm thickness.
    Initially it will be used as a flat-ish and square-ish surface onto which parts can be clamped to weld together the frame for my upcoming CNC router build....... Because my dodgy back would never allow me to bend down and weld on the floor!
    I'm curious as to what it's previous life purpose might have been........ I haven't noticed any wounds from machining or grinding. Anyone have an idea?
    I'd hazard the base for a router unit or a spindle moulder
    If you can't fix it with a hammer you've got an electrical problem !
  3. The Following User Says Thank You to Nthkentman For This Useful Post:
  1. Help on a couple of "niggles" with my machine.
    By Washout in forum Machine Discussion
    Last Post: 24-04-2014, 12:30 AM
  2. CNC machine "Spanish" model . Advice and opinions needed!
    By shapebusters in forum Machine Discussion
    Last Post: 12-03-2014, 06:21 AM
  3. BUILD LOG: My baby 15" x 15" machine
    By wilfy in forum DIY Router Build Logs
    Last Post: 19-03-2013, 09:16 PM
  4. "Racks" VS "ball screw"
  5. Calibrating my new machine - "never the same twice" woes
    Last Post: 23-11-2011, 05:54 PM
