    OK guys i got the touch probe working (ish)
    The bit touches the ali plate - stops and backs off
    comes down again slower - stops
    but rather than reset above it drives the tool down!!
    for the purpose of the video - "PLEASE NOTE: No innocent tools were hurt in the making of this video. collet is loose and the tool is wounded volunteer" the thud at the end is the escape key being pressed.
    http://youtu.be/6pdbWh9RMbc
    Presume your using gerry's screen set.?
    Have you set the clearence plane.? and is the number positive not negative.?
    With all the issues you have been having with changing axis directions etc could you possible have the Z axis going in wrong direction.? IE down = positive Z axis are nearly always negative moves down with positive up.!
    Test by zeroing dro clear of any obstructions and typing G1 Z-5 F100 in the MDI box. This will move nice an slow 5mm down. If goes up your set wrong.!
    Cheers JAZZ,
    yeah im using said screenset.
    I done G1 Z-5 F100 and the axis goes down 5mm
    Clearance is +5.000
    still driving intop the plate
    screen shot - http://prntscr.com/51wias
    went into the simple zero file does this make sense?
    Else ' Off = Metric Measure MM
    FirstProbeDist = 150.0 ' Probe down 150mm
    FirstRetractDist = 1.0 ' Then retract 1mm
    SecProbeDist = 6.0 ' Then probe down 6mm
    FirstProbeFeed = 250.0 ' First probe feed @ 250 mm/min
    SecondProbeFeed = 25.0 ' Second probe feed @ 25 mm/min
    ClearAllow = 2.0 ' Max Allowable Clearance = Z Machine Zero - 2mm
    i cant read that lol
  5. #15
    now sorted... doesnt make sense to me however. set the material clearance to 20mm then an offset of 4.3 and its spot on.
  6. #16
    Quote Originally Posted by D-man View Post
    Those are hard coded default values, and have nothing to do with the issue.
    Really, there should be no way that it can plunge down after probing.
    I'd need to know what the message on the screen said after it plunged down.
    PS. Your collet nut is too loose.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  7. #17
    Sorry Gerry, did I spoil it for you by leaving it loose lol sorry pal.
    Wife's just cooking me some steak and peppercorn sauce, I can't go anywhere until I've destroyed it, so will pop to the factory afterwards and let you know.
  8. #18
    I will reset to default values and do another video for you Gerry with screen included
  9. #19
    OK after setting back to defaults (when the bit plunges) it says that the "Z axis is now Zeroed"
    video uploading
  10. #20
    Ok Setting back to defaults with 3mm clearance. still goes down.
    http://youtu.be/dlAoPufx4ck
    Second attempt, with clearance set to 20mm Goes up! but plunges too far when set to top of work piece.
    https://www.youtube.com/watch?v=Jo4E...AUlD8w&index=2
    Third attempt, works great with a 5.3 offset and same settings as above. go to zero and it just kisses the work piece
    https://www.youtube.com/watch?v=wg7J...AUlD8w&index=1
    i do have safe Z set in mach would that affect it (Back at home now)
  1. Torch Height control
    By Bobp in forum General Electronics
    Last Post: 02-09-2017, 11:25 AM
  2. uPVC CNC Corner Cleaner
    By StuH in forum Machine Discussion
    Last Post: 19-07-2013, 11:09 PM
  3. 1/4" / 6mm edge finder?
    By jcb121 in forum Marketplace Discussion
    Last Post: 18-03-2013, 01:58 PM
  4. Driver wiring to my computer for mach3 to control
    By AdCNC in forum Motor Drivers & Controllers
    Last Post: 31-03-2010, 11:27 PM
  5. Electronic edge finder: how do they work?
    By irving2008 in forum Probing, Digitizing & Scaning
    Last Post: 29-08-2009, 09:25 PM
