Page 3 of 3 FirstFirst 123
  1. #21
    So this is what arrived today:
    https://www.amazon.co.uk/dp/B071DXGG..._TE_item_image
    Must say I'm quite impressed. A sintered filter and a one way valve on the fluid line. Two needle valves and a 5/16" air line push fit. Rigged it up to a small air brush compressor and it works a treat. Obviously I need a bigger compressor to get max air flow but the venturi works even at air brush outputs.
  2. #22
    Quote Originally Posted by Will_D View Post
    First make it to work, then be impressed. I did my first one using chinese needle valve for 5$ and it ended breaking seal after 5 min. Now i use Italian made valve and have not had any problems since. Valve must be good or it will not work properly.
  1. Misting Systems - where in the UK?
    By Chaz in forum Marketplace Discussion
    Last Post: 26-06-2013, 04:38 PM
  2. CAM systems
    By Rob Stewart in forum CAD & CAM Software
    Last Post: 05-08-2011, 06:24 PM
  3. Hypertherm Plasma Cutting Systems
    By Hypertherm John in forum Milling Machines, Builds & Conversions
    Last Post: 04-03-2011, 02:46 PM
  4. any one know about auto lube systems?
    By graffian in forum Milling Machines, Builds & Conversions
    Last Post: 02-03-2009, 05:52 AM
