    hi im looking at some cnc router bits to buy and i need some advice since im new to this.
    i want to be able to cut 2D parts and also do some engraving of texts. is the part below ok for text engraving, if not what could i use this part for.
    http://www.ebay.co.uk/itm/ELU-E45114...item35c03ae249
    is this the part below ok for 2D cutting? thanks. any further advice appreciated
    http://www.ebay.co.uk/itm/ELU-HSS-TW...item35c0a4aa32
    It might help if you mention what material you want to cut.
    sorry, its for both softwood hardwood
    Quote Originally Posted by Skydeals View Post
    Unless you want text where the bottom of the cut is rounded.
    This is the best I've found for text, they also do a 60deg cutter if you want deeper or finer cuts. They come to a fine point for the smallest text. http://www.wealdentool.com/acatalog/...egree_718.html
    They would do, but for rough cuts I use these cheaper ones; http://www.toolstation.com/shop/Powe...+x+12mm/p67412
    Then for finishing use something better from Wealden or Axminster.
    To cover the basic necessities You would like to have:
    2D jobs:
    - 3mm/ 1/8" and 6mm/1/4" 2 flute square end or fish tail , for general profiling. Fish tail is better for wood, 30 degree spiral upcut.
    - ~20mm for pockets and surfacing , 2 flute square end
    - 3mm/1/8" and 6mm/1/4" 45 / 60 degree V cutter or engraver for Signs and letters. 60 degrees is better, 90 degrees is for bigger signs and bigger size like 1/2".
    3mm/1/8" 30 degrees is best for small details, molds from plastic and so, but breaks very easily, so better option is to be engraver/flat tipped/.
    V cutter is not the same as engraving bit.
    For smallish details you would need 1-2mm 2 flutes, and for deeper jobs you may need extended shank or long reach.
    Its up to you but i prefer to have 2 types of each before mentioned.
    One type is stub length, means 6mm shank and 6mm LOC , other is maximum LOC, 1/4 shank -1"LOC
    Generally the best is to arm yourself at first with 3mm /1/8" solid carbide bits and cheap 6mm HSS
    3D jobs:
    -big cleaning bit
    -1mm, 2mm, 3mm, 6mm, ball nose , dep[ends on the size and resolution of job. The bigger the shank, the better, same for the above list.
  1. Router bits cutters for the Kress 1050
    By Skydeals in forum Kress Milling Motors
    Last Post: 28-10-2014, 08:25 PM
  2. TCT Router cutters in a mill running at 4000 RPM
    By suesi34e in forum Tool & Tooling Technology
    Last Post: 26-02-2014, 07:02 PM
  3. Router Cutters
    By sfallan in forum Tool & Tooling Technology
    Last Post: 26-08-2011, 08:23 PM
  4. Wealden Tools enlarge range of spiral router cutters
    By Routers in forum Manufacturer News
    Last Post: 01-07-2011, 11:42 AM
  5. Cutters for alu and mdf
    By Tom in forum Tool & Tooling Technology
    Last Post: 16-11-2009, 09:26 PM
