Thread: A few MDF bits
    Not as exciting as some of these stuff in this section, but its a start - with the machine running flawlessly!!
    few bits for the kids and couple lads at work for theirs.
ID:	13789   Click image for larger version.
ID:	13790   Click image for larger version.
ID:	13791   Click image for larger version.
    Looks great, seems to finish the mdf well, did you have to sand it to clean up the edges and flat spots?
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
    Cheers, The only sanding that was done was from the hold down tabs ;) it's a little fluffy but not massively.
    I will experiment with one at some point with PVA glue to seal it/sand it/ then paint it with the kids.
    Nice looking signs, what spindle speed were you running at ?
    Quote Originally Posted by D-man View Post
    You've got to seal it becasue I believe it gives off formaldehyde gas, also if left bare it acts as a breeding ground for mould etc.
    Oh well I can't give the kids them yet!! Looks like that's my job.
    I'm not sure that the spindle was running at if im honest as I'm new to the VFD but said 3100
    Bits used were a 6mm 2 flute end mill for pocketing and profiling then a 90 degree 19mm V bit to also clean the profile lines up down 1mm
    I got one of these to check my own spindle and to calibrate the vfd display, works great.
    http://www.ebay.co.uk/itm/Non-Contac...item5d4576cd51
  8. The Following User Says Thank You to EddyCurrent For This Useful Post:
  9. #8
    Nice jobs well done, where did you get the project files from for the jobs
  10. #9
    Quote Originally Posted by Andrew C View Post
    Ah, just seen this after replying to your previous post and now see what the question really was.
    Answer in many cases is the same, though - people design their own. For things like house signs, Vectric Vcarve (or one of their other products in the range) is difficult to beat but not cheap. Can save a lot of time, though. It comes with a library of motifs and similar, and you can buy other designs (but I haven't done this myself so no idea of prices and so on).
    Otherwise, there are some 3D CAD packages (Fusion 360, Solid Edge, for example) that quite a few of us use. There are also some freeware CAD and other design packages around that others prefer.
    The nameplate for my own house includes a relief carving of a badger's head that was derived from a series of photographs of a model badger, processed by some clever software that is no longer available, and turned into a machinable model via Vectric 3D. That's one route, but don't try to make a profit going down that path - it took me ages.
  1. FOR SALE: Bits for Sale
    By petesurrey in forum Items For Sale
    Last Post: 27-10-2011, 06:55 PM
  2. FOR SALE: Some bits for sale
    Last Post: 08-03-2011, 02:43 PM
  3. RFQ: need someone to cnc/mill some bits for me
    By neurofen in forum Projects, Jobs & Requests
    Last Post: 04-02-2011, 10:13 AM
  4. best drill bits
    By oadamo in forum Tool & Tooling Technology
    Last Post: 01-01-2011, 11:25 PM
