Thread: Boxford TCL 160
Here's the page on the Boxford Spares site:
http://www.boxford-software.com/spares/160Turret2.html
I don't have a manual for it; I just dismantled slowly and made notes as I went.
My problem was also the indexing, in that the pressure from the springs on the pawl would stall the motor and stop the thing from turning. I cleaned it all out and re-greased it and it has been fine ever since.
Adrian.Last edited by Saracen; 23-05-2017 at 01:30 PM.
23-05-2017 #2
I did exactly the same for the same problem but I also increased the pulses and it helped a lot it also made locking more precise.
23-05-2017 #3
I did wonder if the motor was getting weak but it seems to have been fine since.
Would changing the motors and/or drivers speed up the movement ? I'm still using the Boxford drivers and motors, but controlled with a PlanetCNC Mk2/4 board.
Adrian.
23-05-2017 #4
23-05-2017 #5
Ouch
31-05-2019 #6
Hi
Not sure if you can help or not but I've got the same problem you had with the turret gear, I've bought a new gear from boxford but just wondered if the gear is timed up to the turret station stops in any way or is it just placed on the shaft with the gear teeth sitting any place you want, I'm assuming you have bought a new gear also and repaired the turret as apposed to buying a new one as they are so expensive?? Any help would be very much appreciated,
John
31-05-2019 #7
If I remember correctly the shaft had a key way in it. To locate the gear.
31-05-2019 #8
Hi
Firstly thanks for your reply,
Sadly no keyway whatsoever on mine it was secured in with two grub screws at the end face of the shaft. The issue with this is I would need to drill 2 new holes and tap them to secure it again this way.
I've had a look online on boxford website and they sell the grub screws and the gear has no key way slot in it so I assumed all must be done that way??
John
Boxford 260 VMC
By shoeswith in forum Boxford Vertical MillsReplies: 3Last Post: 10-04-2017, 06:20 PM -
eBay: Boxford 125 TCL
By magicniner in forum Items On eBay UKReplies: 0Last Post: 30-07-2014, 06:44 PM -
boxford vmc 300
By bigred5765 in forum Boxford Vertical MillsReplies: 0Last Post: 22-04-2014, 04:22 PM -
Boxford mt2
By Hellfire in forum Boxford LathesReplies: 6Last Post: 03-08-2012, 08:46 AM -
Boxford 160 TCL
By Brinner in forum Boxford LathesReplies: 1Last Post: 31-03-2012, 09:11 PM
