    Hi all,
    Working on my first design, having read various sites and postings I have the basics of what I want to do.
    When looking at the Z axis design and pricing it up using square rails etc I noticed this pre built Z axis
    http://www.cnc4you.co.uk/CNC-Kits/Z-...ess-plus-Mount
    Is it worth the hassle and expense designing & building one from scratch, or just go with an item as per the link?
    Unless I can get a clear performance advanage seems not...
    Looking to machine woods and Aluminium, on a 1200x800x100 machine.
    I looked at that myself some time ago but decided not for several reasons.
    It used unsupported rails, it was the wrong size for my design, the spindle I used needed a special/modified mount, I didn't like just one linear bearing per side (even though they are the longer ones), I thought I could build one cheaper and better, it has a direct drive mount for the stepper but I wanted belt drive.
    Quote Originally Posted by 9designs View Post
    Yes it very much is worth the hassle of building one has the Z axis is THE most important area of the machine as it's taking all the cutting forces so if it flexs the results show in finish quality. Doesn't matter how good or well built rest of machine is if Z axis flexs the results will be poor and inaccurate.!!
    Regards the linked Z axis then it's Terrible design that as everything you don't want in a Z axis, namely Unsupported rails with not enough bearing support and overhanging front plate. (completely useless for machining aluminium with.!!)
    Also the aluminium plate looks like standard hot rolled plate that hasn't even been surfaced flat and true. So any chance of accurecy is none existant as 99% of rolled plate isn't flat.!
    For accurate and true Z axis you need surfaces machined flat and parallel or use Machine ground cast tooling plate which is what I use. It's surfaces are ground flat and parallel to each other also being cast plate it's very stable and doesn't distort when machined.
    Thanks for the feed back... It's bit a chicken and egg situation, I could easily design something I can't make..... because I don't have a mill/router !! ... Challenge is keeping the design achievable, without spending a fortune on someone machine loads of stuff up for me. So those lovely fully machined parts will probably have to wait to the second build ;)
    I have a layout with supported Hiwin rails and 4 carriages, with the motor spindle axis more or less between the rails in Y, looking to minimise the offset from the support to cutter axis. Some of the material/block size are a bit light at present so I'll keep tweaking the design before posting any screen shots.
    Also looking how to tie the Z axis back into the gantry.
    If it's any help I made my machine with woodworking tools (other than the welder for the frame), bandsaw (standard wood blades cut aluminium), router and standard carbide cutters for wood (cut aluminium okay, just use small cut depths), bench drill, small angle grinder with metal cutting discs, sabre saw with metal cutting blades, disc sander. Then the usual hand tools such as files, hacksaw, etc.
    If you use machine tooling plate and profiled linear rails then it's not very difficult to build a very good Z axis with just a Bench saw and drill press.?
    Tooling plate removes any need for machining surfaces true and parallel which is a big help in achieving accuracy.
    Profiled linear rails provide smooth action and accuracy due to being built to much higher tolerances and stiffer than round type rails but they are also much less tolerant of error so tooling plate helps here also.
    One issue with profiled linear rails is the lower profile means a channel needs machining in the plates to allow clearance for the ball screw but this is easily done with the table saw and router.?
    First clear out most of the material using the table saw by stepping over blade thickness at a time so nibbling away material. Make the width & Depth just less than finish size. Then use the router to clean up and take to finish depth/width.
    For accurate hole locations then make paper templates and stick to material. Then carefully centre punch and drill using drill press.
    Same procedure can be done for shaped parts like gantry sides etc, make MDF and paper templates and use guided cutter in router.
    Stick paper template on material then cut slightly oversize using a jig saw then fasten MDF template on material and finish to size with guided cutter.
    Cutting aluminium with wood blades is easy, so much so that my old knackerd saw blades that struggle to cut hardwoods without filling shop with smoke easily cut 20mm aluminium. Thin kerf blades are best.
    Any Carbide router cutter will cut aluminium but with router you'll want to take shallow depth cuts depending on router power and how brave you are.!! . . . Go too deep and it will jump and chatter like tigger so you'll soon know.
    Go for it you'll be surprised what you can achieve with hand tools and patience.!
  8. #7
    Thanks for the tips and encouragement TBH I wouldn't have tried my router on aluminium... so something new to try.
    Some general questions from reading and looking at some of the designs.... What strikes me is there is a lot over engineering in frames etc. Ok that's needed in context of cutting duty.
    I'm thinking MDF, Plywood and Aluminium plate, with 3- 10mm cutters I assume.
    Some of the frames are huge steel welded section, the likes which I've made/designed in the distant past to hold large diesel generating sets.... Then heavy steel gantries on top.... Seems OTT for such cutting duties.
    I'm not expecting to machine steel billets, for a start I'm thinking of a Kress 1050 spindle, which I guess could be the limiting factor on loads.
    I also want to use 3 4mn Nema 23's... So I have an eye on the weight.
    Having looked at the designs here I'm reluctant to post my CAD design now, as its a way off what I see. For example running FEA analysis on say a single 1200mm length of 25mm x 200mm Marine plywood gives 0.0X range of deflection with a 50 Kg load.
    So little puzzled at present....... I've kept it to aluminium, thinner sections and orientated in the direction I expect the load and bolted.... ie trying to consider the "I" value/Second moment of area.
    I have an open C sections to refine at present, a brace across could do it.
    That said some impressive machines on here.....
    Happy New Year...
  9. #8
    Yes they are well OTT has my recent little rant tried to highlight for new users just like you.
    If your into engineering then you'll have a good idea of whats required material strength wise so just apply common sense. The things to think and design around are resonance, flex along with plenty of adjustment built in to account for the DIY factor.
    The most important area and under estimated is the Z axis. It's at the sharpe end taking all the cutting forces directly so any weakness here will show in the finished work.
    Going back to the Z axis and cutting forces. The spindle power is key to balance and all those OTT engineered machines you've seen are under powered in the spindle department, by long mark in many cases. That is just waste of money, resources and time IMO which actually reduces the machines capabiltys not improves. IE: Lower acceleration or rapid feeds.
    For a serious DIY machine that will cut everything upto aluminium and do it for lengthy periods then don't use a Kress spindle. They are toys in comparison to the chinese Water cooled spindles and not much cheaper.
    Weight wise then 3 or 4Nm nema23's with the correct drives and voltage using ballscrews and profiled linear rails will be ok upto 70-80Kg Gantry and give good speeds with correct pitch.
    Regards your design then don't hold back post it up for us to see. It's the best way to iron out any grey areas.
    I'm not a fan of wood machines for several reasons which have been said but what you have to consider is the main use of the machine. If soley or mostly Wood use then it will be fine if designed correctly. It won't be cheaper than steel thou and much weaker.
    If your thinking to cut aluminium then just plane forget using wood it just won't work reliably over time and be repeatable. Cutting Aluminium correctly takes the machine into another level. Yes most any machien will scratch it away but thats not cutting and does take it's toll on machine and tool life if not designed for it.
    For a first machine I'd recommend you concentrate on the wood use only and build it the best it can be to do that.
    Go for it and DONT let those Massive builds put you off it's NOT REQUIRED.!. . .
  1. Replies: 15
  2. Replies: 4
    Last Post: 02-01-2015, 08:32 AM
  3. Some design questions
    By cropwell in forum Gantry/Router Machines & Building
    Last Post: 08-06-2014, 03:07 PM
  4. Replies: 2
