31-12-2016 #51
31-12-2016 #52
I am using the Zapp BoB ZP5A-INT and the NPN proximity switches as suggested by Jazz some time ago. I posted this a couple of months ago, but could'nt get it working. I have a separate 24v PS for the relay safety system which I also wanted to use to power the prox switches. But if you or Jazz can give me some inspired thoughts I would be grateful
Regards
Mike
27-01-2017 #53
Hi Jazz, manage to get rid of the noise by doing everything you said and using an IEC EMI filter socket for the mains input to the control box, as well as using a ferrite coil around the RS423 Modbus serial connection between the Mach3 PC and the VFD. Now it runs reliably. Got all the bits for my dust filter and about to cut the dust shoe from 10mm perspex. Will post the design and pics soon.
Cheers.
Mike
27-01-2017 #54
Dust extraction should be a priority especially if you intend to machine MDF. It uses urea-formaldehyde as a bonding agent and the formaldehyde is a proved carcinogen besides other harmful effects.
Just watched your video and it doesn't look good to me with all that fine dust.
The Following User Says Thank You to paulus.v For This Useful Post:
27-01-2017 #55
The cyclone cones you get off eBay are good, just hooked one up to my machine and works brilliantly, I'd highly recommend one Mike.
What you see in the bottom of the CamVac (virtually nothing) is after machining plastic for an hour and hoovering wood dust up off the floor.
The Following 2 Users Say Thank You to njhussey For This Useful Post:
30-01-2017 #56
Hi Paulus & Neil
Great minds do think alike and you are both perfectly correct. Since the video I have'nt done anymore cutting because I realised with the amount dust created just by surfacing, I needed a filtration system. So I ordered a cyclone off Amazon for an amazing price and lots of hose as shown below. I have an old VAX (2000 watts before the EU restrictions!!!) which should do the trick. Also making a dust hood for the spindle based on a design I found on Bjorn Makes YouTube Channel here
29-03-2017 #57
Hi Guys
Following on from the last post, I built my cyclone dust collector, and promptly crushed the barrel, when I put my hand over the end of pipe to check the suction!. Using a hot-air gun, I manged to un-collapse it and restore it's shape. Hunting around on the web, I found a design for a pressure relief value (here) and this design here using a 40mm PVC straight coupler and a neodymium magnet and it works brilliantly!
see pic
Also, I have started some test cuts for the dust hood (see previous thread for youtube link!) and really pleased with the accuracy of the machine. The inner ring is 70mm dia +- 0.01mm!!
There are a couple of toolpath issues to sort out, but the code from Estlcam worked first time!
I post a video on Youtube later.
Now just have to get the proximity switches working and we are fully done and ready to make chips!
Regards
MikeLast edited by MikeyC38; 29-03-2017 at 09:34 PM.
10-04-2017 #58
Hi Guys
Sorted out the problem with the toolpath by upgrading to Estlcam v10 and defining the operations in a different order.
The photo attached shows the final dusthood cut from 10mm perspex sheet using a single flute carbide cutter running at 12,000 rpm, 600 - 900mm/min feed and doc of 1-2mm. Took around 1hr for the all operations. The link to Youtube shows the last operations. I'm pleased with the finish of the pocketing. Now to get on with doing some real projects!
Kind Regards
Mike
10-04-2017 #59
Nice cut! It looks very similar with my first dust shoe. But now, mine have diameters of 15 to 25 cm calculated for different tools dia so that the hair will not be cut by the tool at any depth. And also dependant of the hair length/ depth of cut.
18-04-2017 #60
Setup for squaring twin X-axis gantry
By routercnc in forum Gantry/Router Machines & BuildingReplies: 20Last Post: 26-03-2014, 11:13 PM -
BUILD LOG: New build - fixed gantry mill using extruded profile
By toolchimp in forum DIY Router Build LogsReplies: 3Last Post: 09-11-2012, 04:10 PM -
NEW MEMBER: New Member build finally started in Oxfordshire
By pjchick in forum New Member IntroductionsReplies: 1Last Post: 26-11-2010, 04:02 PM -
BUILD LOG: Flying Gantry Build Diary
By geoff.sim in forum DIY Router Build LogsReplies: 8Last Post: 29-05-2008, 02:53 AM
