Page 2 of 2 FirstFirst 12
    Hmm, so what qualifications do you think would be appropriate in this case?
    Well in case anyone else has this question, an appeal on another forum was more helpful. The programming procedure is described on pages 57 to 59 of the manual. The maximum frequency tFr and the high speed setting HSP need to be set to your desired maximum speed in Hz. Turned out to be easy peasy.
    Small correction - it's uFR for max frequency, not tFR. Logical I guess.
  1. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 11:57 AM
  2. maximum deflection - sanity check
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 11-02-2013, 08:33 AM
  3. Maximum size of box section, Stacking box section, Construction Angle
    By andy586 in forum Gantry/Router Machines & Building
    Last Post: 01-02-2013, 04:29 PM
  4. Maximum length guideline for a standard 16mm ballscrew?
    By WandrinAndy in forum Lead Screws, Nuts & Supports
    Last Post: 31-10-2012, 11:27 PM
  5. maximum amps
    By petejw in forum General Electronics
    Last Post: 11-08-2009, 10:40 PM
