Thread: Z-Axis setup
    Hello Everyone,
    I am new to CNC machining. I have built my X, Y axis. Also I have the frame built which is 16 inches x 16 inches (406.4 mm x 406.4 mm) as well as the stepper motor driver but I am confused as to the best approach for designing and building the Z-Axis. Can some please help?
    By the way, the Y-Axis and Z-Axis will act as a single unit.
    Thanks in advance
    You don't give many details of what you have already, but this is as good a Z design as any; http://www.mycncuk.com/threads/7812-...1686#post61686
    This was the design for my own machine; http://www.mycncuk.com/threads/6565-...5686#post55686
    You can also look through these build logs to see if any other designs suit your application; http://www.mycncuk.com/forums/253-DI...ter-Build-Logs
    This diagram shows some key points regarding design; http://www.cncroutersource.com/do-it...NC-router.html
    JAZZCNC's Avatar
    Lives in wakefield, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 6-7 years. Has a total post count of 6,205. Received thanks 1,015 times, giving thanks to others 42 times.
    Quote Originally Posted by Yaser View Post
    [/B]By the way, the Y-Axis and Z-Axis will act as a single unit.
    Think you better explain this one because you got me head scratching.?
    Z axis design wants to be strong and uncomplicated. Short as possible with good bearing spacing. Widest foot print as possible on the rear plate where it meets the connecting axis which in your case I've no clue what your meaning. . Lol
    Don't use thin flimsy plates.
    For ease of building and setup then you don't need a bottom bearing on the ballscrew if screw not too long.(upto 350mm) Optional if you connect motor to screw with a timing belt but doing so is better for resonance reasons and gives option of a ratio if required.
    Usually stronger if rails are placed on the front plate, thou dependant on travel amount not always the case.
    Draw it up and let us take a look. Pics of what you have so far will help also.
    Thanks for the information. I was wondering where I can find some hobby spindles that are not too epensive. I will look over the links and let you know if I have any questions.
    Hi Jazz,
    Thanks a lot for your input/advice. As I mentioned I am new to CNC building so please pardon me if the questions I ask seem trival.
    Can u please elaborate the following:
    1) Widest Foot print possible?
    2) What would be considered to be thin flimsy plates?
    I will try to have some pictures and perhaps u can comment on what can be adjusted.
    Thank you very much
    JAZZCNC's Avatar
    Must be invisible so removed.
    What's was invisible.?
    Glitch, ignore.
  1. Setup for squaring twin X-axis gantry
    By routercnc in forum Gantry/Router Machines & Building
    Last Post: 26-03-2014, 10:13 PM
  2. 2 motors on X how do I setup Mach3
    By phill05 in forum Artsoft Mach
    Last Post: 04-02-2013, 08:33 PM
  3. FOR SALE: 4th axis setup
    By johngoodrich in forum Items For Sale
    Last Post: 13-06-2012, 05:17 PM
  4. CNC Machine Setup Blog
    By marchantdice in forum General Discussion
    Last Post: 17-10-2011, 07:31 PM
  5. Motor & Driver setup
    By action-kat in forum General Electronics
    Last Post: 19-07-2010, 10:24 AM
