    dazza's Avatar
    Lives in leicester, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 363.
    Does anyone use the above?theres a massive price difference compared to the likes of bison chucks so im wondering about their quality/accuracy.
    The main difference with a collet chuck is that the run-out is generally much lower than for a normal 3-jaw chuck. That doesn't necessarily make your parts more accurate though - if you can machine the part in one set-up, without removing it from the chuck between operations, then the end result is the same. If 1-10mins setting up the part concentrically in a 4-jaw chuck is not a problem, you might as well do that as it's a lot cheaper.
    Collet chucks also grip over a larger area, so can potentially hold with a higher stiffness and are less likely to make marks on the part.
    dazza's Avatar
    ta,my other reasons for looking at collet holders are pneumatic release and bar grabbing.
  1. Replies: 1
    Last Post: 29-01-2013, 11:05 AM
  2. WANTED: collet chuck
    By Miniman in forum Items Wanted
    Last Post: 13-12-2012, 05:26 PM
  3. WANTED: ER20/25 straight shank collet chucks
    By m_c in forum Items Wanted
    Last Post: 24-10-2011, 12:19 PM
  4. Question regarding CMD 10 Collet sets
    By Englishlever in forum Tool & Tooling Technology
    Last Post: 07-09-2010, 10:10 PM
  5. What Collet Chuck have I got?
    By irving2008 in forum Tool & Tooling Technology
    Last Post: 24-11-2008, 08:41 AM
