Thread: new laser
	25-05-2009 #1Hi
 Got this off Ebay last week, it didnt sell so the owner (Keron) lowered his asking price to £0.00 -Just needed to get it out of the way.
 Very big, fills the loading bay completely so I will have to remove some of the floor to get it in.
 Heidenhain controller, 500 watt ferranti laser, 3m x 2m cutting. Should be good for 20mm plastic and 3mm mild steel, which is nice as our small machines and control panels are 2 and 3mm thick steel.
 Also bought a 25hp Ingersoll Rand waterjet intensifier 56,000 psi at 1.9 litres/min £1,025. Going to build a tank and stick our motion on it, low cost waterjet cutting facility.
 Amazing, to buy both these machines new would be £200k +, so thats a saving of about £195,000.
 Difficult trading conditions out there at the moment so its a good plan to try and reduce your manufacturing costs, its also good fun buying toys, wonder what I could make out of laser cut plastic, apart from signs and stuff?
 mike
 techserv
 PS been nominated for a Tata innovation award, innovation in a shitty mill in Dewbury - who would have thought
	25-05-2009 #2Yep, we have tea, coffee, water and sometimes biscuits. You are more than welcome. Give us a call beforehand as I am out quite a bit.
 Mike
 01924 460456
 Re the panels, yes could do, are the drawings avaliable and what material? Given that I can get the thing working, I am happy for anyone to call in and cut their own stuff. No doubt someone might have some insurance issues but Im sure we could sneak a bit of time after hours. Got to take a chainsaw to the floor first! :naughty:
	26-05-2009 #3I can send in some Hobnobs ? Lee
	26-05-2009 #4
	31-05-2009 #5I was trying to start a 'bring a bun' policy for all non-purchacing visitors, but biscuits will be fine, how about hobnobs with caramel. Or better still if we have some bits that you want we could swap them for their weight in biscuits, might have to set some limits, perhaps a minimum payment of 2 biscuits and no maximum
 We have removed the floor to fit the laser (this is the 'royal we' as I've done nowt due to a brief holiday). The laser is very big and heavy, uses a heidenhain cnc and a moving table, ballscrew and spinning nut, looks to weigh about three tonnes, which might be a struggle for our 2 tonne crane.
 Mike
 Techserv
	31-05-2009 #6Mike,
 It may pay you to remove the laser off the top whilst installing the machine.
 If that takes a knock it's virtually impossible to get back aligned again.
 Those Ferranti's can be pigs to tune.
 Early ones were filed with Fluorocarbon, later ones deionised water, whatever happens make sure the ballast resistor box in the bottom is bled before starting, one air bubble and it frieds the ballast resistors, - don't ask.
 .John S -
	06-06-2009 #7Thanks for the advice John, laser removed to a place of safety, in fact almost every thing removed, too bloody heavy to lift with our crane. Now in position ready for a rebuild, might have a bit of a hunt round for a higher power laser. I'm told there is a chap in Wakefield deals in them. Water jet machine going togerther shortly and looking out for a 3 metre pressbrake.
 Thanks for calling in Kip, sorry to have missed you, had to do the holiday thing, next time perhaps. Did you get the full tour of 19,000 square feet of junk or just the main workshop?
 Mike
  Laser cutterBy John S in forum Laser Machines & BuildingReplies: 8Last Post: 02-06-2012, 02:16 PM
  WANTED: GCc Laser Pro or Epilog Laser Cutter MachineBy Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM
  RFQ: Cnc or laser cut steel bracketsBy don_jarr in forum Projects, Jobs & RequestsReplies: 4Last Post: 12-04-2012, 09:23 PM
  help with cnc laserBy swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM
  Laser powerBy John S in forum Laser Machines & BuildingReplies: 9Last Post: 26-08-2009, 09:53 PM
