1. I have a 1 1/2HP DC motor on a lathe that has a manual veriac controller I would like to change to electronic speed control has anyone done anything like this and can point me in the right direction where to obtain one please.
    Phill
    There's some DC drives here; https://www.inverterdrive.com/group/...V%2f240Vac+1ph
    but you would need to find out if your motor is compatible.
    Or maybe you could replace it with an AC motor and inverter drive.
  3. Thanks Eddy,
    The motor and controller was new 2000 - 2001 so don't want to change the motor just the controller box as it's big at 350 mm square, the supply to NECO box is 240-250Vac and I think the field supply to motor was 170 - 180Vdc
    Phill
    These Parker drives are quite good, this one looks like a candidate, but needs confirmed first.
    https://www.inverterdrive.com/group/...er-Drives-505/
  1. Help for MOTOR 2.2 Kw and control board.
    By BILLYBOUM in forum Spindles & Drive Motors
    Last Post: 26-11-2014, 02:35 PM
  2. Emco C5 spindle motor control
    By GeoffV in forum Motor Drivers & Controllers
    Last Post: 19-03-2014, 03:20 PM
  3. Mach 3 control of DC Brushless motor?
    By templecorran in forum Artsoft Mach
    Last Post: 18-11-2010, 03:20 PM
  4. motor control
    By Phil Gravett in forum Motor Drivers & Controllers
    Last Post: 09-06-2009, 04:02 PM
  5. Motor control
    By crazy horse in forum Gantry/Router Machines & Building
    Last Post: 13-03-2009, 08:31 PM
