Page 2 of 2 FirstFirst 12
    You can use an engraving spindle which takes a Gravograph nose and allows cutting depth to be set by the amount of cutter protrusion, a nose with a pivoting ball with through hole for the cutter allows engraving over 10 degrees either way around a 20mm cylinder with a 2D engraving job
    http://www.gravograph.us/engraving-p...Nose_Cones.php
    [QUOTE=magicniner;65341]You can use an engraving spindle which takes a Gravograph nose and allows cutting depth to be set by the amount of cutter protrusion, a nose with a pivoting ball with through hole for the cutter allows engraving over 10 degrees either way around a 20mm cylinder with a 2D engraving.
    That only works fine for 2D engraving if everything is to be engraved at the same depth. G.
    By mounting a spindle with this type of nose on a vertical sprung slide (to mimic the original use where hand pressure on a manual pantograph kept it at it's set depth) one can engrave on convex, concave, rippled and non-level surfaces.
    The text on this 20mm radius curved Titanium sheet part is about 3mm high -
    It's possible to engrave 3 or 4 lines of text on these 20mm radius parts without noticeable depth/width variation.
    Geoffrey,
    If you want 3D engraving you just set flat parts perfectly level, anything else you model the surface for and then set up your part in exactly the orientation in which it was modelled,
    Regards,
    Nick
    Thanks Nick, I am aware of what you are saying, I was merely making the point that whilst a fixed projection from a spring loaded toolholder will follow the existing surface and ensure a steady depth below that surface, it will not allow engraving at different depths. I do have a card/vynal cutter that uses exactly that system. G.
  5. #15
    Does a spring loaded cutter with no depth guide allow accurate variable depth engraving over an uneven surface?
    Or will changes in surface height change the pre-load on the spring and vary depth?
  6. #16
    When I referred to a fixed projection, I did of course mean a fixed projection from a nosing that touches the surface. G.
  7. #17
    .... not allow engraving at different depths.
    So what will?
    The OP referred to parts that are not flat, I was responding to the OP with ideas that might help achieve fixed depth on curvy surfaces
  8. #18
    Here's another spring loaded tool
    http://www.mrrace.com/SpringTool/index.htm
  1. NEW MEMBER: New to CNC and need some tips for what to look for when buying a laser cnc
    By veviben in forum New Member Introductions
    Last Post: 12-12-2014, 08:28 PM
  2. Replies: 0
    Last Post: 16-06-2013, 12:33 PM
  3. Carbide Tips in Packs of 2
    By APT in forum Manufacturer News
    Last Post: 28-01-2013, 10:19 AM
  4. Looking for tips on making 2.5 x 1.25 mtr table
    By psiron in forum Gantry/Router Machines & Building
    Last Post: 14-06-2010, 07:09 PM
  5. Bridgeport Tips & Advice
    By Philmollatt in forum Milling Machines, Builds & Conversions
    Last Post: 01-10-2009, 05:34 PM
