    I'm try to find a way to keep my hywin rails free from collecting dust as I have noticed that after a while can accumulate and get stuck to the rails and coarse problems. I am in the process of sorting the dust extraction that will help a certain amount but I would still like to have something in place to try and minimise it further. The dust is mainly from milling foam so quite light but has a lot of static and likes to get every were. I have experimented with putting brushes on the ball screws that seams to work however it is a little harder with linnear rails. Hywin do a scraper seal kit with I have been looking at bit have been trying to figure a way to get closer to the problem to minimise it before relying on the scrapers. Are there any good solutions out there ? I have been wondering about some sort of compressor linked up to a Number of small tubes blowing the dust of the rails but not sure if that would be a expensive solution ?
    If you add dust extraction why not have some additional extraction points fore & aft of the runners on the problem rails to keep them clean?
    To give enuff suction I think you would need quite large tube and more noisy vacuums and I'm struggling with getting that to work with my 6meter x axis as it is I would happily be proved wrong though
    You could reverse the idea and have very close fitting shrouds around the rails on each end of each runner and keep them at positive pressure with compressed air, that should move anything up to and including "leaves on the line" or "the wrong kind of snow" ;-)
    I have seen that on expensive plasma machines. small dc motor with brush, brushing just before the bearing block.
    Could you rebuild the machine with the rails & slides under the bed so that material will tend not to contaminate them and debris will "fall off" rather than "fall onto" the rails?
  7. Not a big fan (excuse the pun) of blowing this stuff around the workshop, think it's best to remove @ source, it's a difficult one due to the static clingy thing, top priority is sort the extraction and wear respirator until sorted,does anyone know if the cyclones work with this stuff or does it cling to the funnel and block it ?
    Regards
    Mike
    cyclones tend to be used to stop large particles clogging /filling the extractor unit, fine material tends to pass through the cyclone and into the filter bay/vac unit,, with coarse material dropping out into a hopper.. as you don't have coarse material I don't think it would work, but could be totally wrong with the right cyclone design.
    Hope your extraction system has sufficient earthing to prevent static build up....if it is plastic I would be looking to run a bare metal strip in the ducting and earthing that
    If your cyclone is efficient enough it should have no problem filtering the foam dust. You can always add a filter to the exhaust to catch what the filter misses.
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
  1. keeping DTIs perpendicular for runouot checks
    By dsc in forum Machine Discussion
    Last Post: 13-03-2014, 02:41 PM
  2. round rails
    By wilfy in forum Rails, Guideways & Bearings
    Last Post: 01-11-2012, 01:10 AM
  3. Why not use unsupported rails?
    By Jonathan in forum Gantry/Router Machines & Building
    Last Post: 06-04-2012, 03:27 PM
