    dudz's Avatar
    Lives in Bretagne, France. Last Activity: 20-05-2017 Has been a member for 4-5 years. Has a total post count of 256. Received thanks 1 times, giving thanks to others 50 times.
    I have a 3 axis CNC USB bob 200khz like this one :
    http://www.ebay.co.uk/itm/2517477394...480%26_rdc%3D1
    There are also available this card :
    http://www.ebay.co.uk/itm/2611636890...018%26_rdc%3D1
    As far as I can see, the only difference between the two boards, is on the 3 axis board there are two Optocouplers missed out for the 4th axis. I have emailed several companies supplying this board and they say they are completely different designs. I doubt that. I have ordered two Optocouplers of the same as the others to see if I can control a 4th axis. There are outputs on the end of the board for the 4th axis if you look. The IC's cost me a grand total of 3 Euros
    3 axis CNC/router / Alu profile frame....25mm Alu Cutting bed X=500mm Y=300mm Z=110mm.....Supported 25mm X rails ....Supported 20mm Y rails....Supported 20mm Z rails.....2.2kw Chinese WC spindle......"USB Breakout Board Interface 200KHz"....M542 Drivers..SY60STH86-3008BF Motors...running....Mach3 / Cambam / Emachineshop.
    dudz's Avatar
    2x more opto's in. No changes. Firmware is the only thing that is restricting the board to 3 axis I think.
    dudz's Avatar
    It looks to me like you connect the tip of the stereo plug to an input pin of the bob and the middle ring of the plug goes to ground. Rather than cut the plug off like they suggested I would get a matching socket, mount it somewhere handy and wire that back to the bob.
    e.g. http://www.ebay.co.uk/itm/3-5mm-Jack...item3cb8d4d762
    dudz's Avatar
    I have already got a socket setup for the probe as it was functioning properly with my previous motion controller board. Now I have swapped this board for the 5 axis BOB, it will not function. It is wired exactly as you just suggested
    Have you tried connecting a mutimeter to it (on ohms range) to see if the circuit makes and breaks when the tip is moved ?
    dudz's Avatar
    It needs between 3V and 24V passing though it to work
    Quote Originally Posted by dudz View Post
    Yes that's to make the LED work but it should still have worked as a probe without the LED coming on
    dudz's Avatar
    yes, as I said it was working right before I changed the bob
    Still no luck
    dudz's Avatar
    No it does not. The probe works though on my Motion control card
  1. FOR SALE: leewood 3 axis controller from an isel 3 axis cnc
    By nobby in forum Items For Sale
    Last Post: 24-09-2014, 08:08 AM
  2. Replies: 3
    Last Post: 18-05-2014, 02:40 AM
  3. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
    By LoveLearn in forum New Member Introductions
    Last Post: 25-01-2012, 07:46 PM
  4. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 01:04 PM
  5. WANTED: Need electronics, anyone upgrading??
    By fasteddy in forum Items Wanted
    Last Post: 25-09-2009, 05:46 AM
