    This is a product stamp I made last year for a friend, it's on 10mm diameter tool steel rod, hardened & tempered after engraving and relieving the excess material around the stamp outline on the grinder -
    This is what it does on hot steel plate -
    It took some time to develop the engraving spindle setup on the mill, this 3D job was performed with no depth guide and the spindle slide mount fixed, not sprung, a depth guide can be added for fixed depth work on nominally flat or fairly smooth 3D surfaces. The rig can be used without rotation for Diamond Drag Engaving down to about 1mm text height.
    This was the setup for my first experiment with a 4-Axis engraving job, it just reads "TEST ENGRAVING" around a 20mm Stainless Steel bar
    Somewhat simplistic but it pleased me, the bar is still on a shelf somewhere ;-)
    - Nick
    Nice engraving, I like your spindle speeder do you a thread on this site about its construction?
    ADD ME ON FACEBOOKS
    That die looks great - very impressive - (pun intended). Well done. G.
  1. RFQ: Small sized Parts need making, small batches
    By Ptee in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 06:07 PM
  2. RFQ: Wood Sign/engraving required, small job one off money waiting...
    By njhussey in forum Projects, Jobs & Requests
    Last Post: 21-09-2013, 07:12 PM
  3. NEW MEMBER: engraving
    By pontinal in forum New Member Introductions
    Last Post: 11-05-2012, 01:02 PM
  4. Engraving pictures
    By Kai in forum Computer Software
    Last Post: 19-07-2011, 09:49 PM
  5. PCB Engraving / Cutting
    By jrob3rts in forum General Discussion
    Last Post: 02-06-2011, 09:35 PM
